Gantry homing move in same direction when siwtch is hit on one side
01 Apr 2022 01:20 - 01 Apr 2022 01:38 #238963 by FrankyBoy
First, thx for the input,
I had a second configuration for an XYZ setup (leaving out Y2) and using only the output signal from Y1 directly to drive Y2 joint.
It is working just fine when I have this setup with only 3 joints including homing of the Y axis.
I have not try to used the Y2 joint to do the homing part alone and will try it next week to see if it is joint related.
At the moment, X and Z axis have no problem homing. They both work just fine.
Last edit: 01 Apr 2022 01:38 by FrankyBoy.
Time to create page: 0.160 seconds
