G76 incorrect pitch
02 Apr 2022 15:09 #239073 by rider-83
G76 incorrect pitch was created by rider-83
Ver 2.8
AC Servo with built in encoder using A/B & Z signals
I'm having issues with the thread pitch whilst using G76
Every thing else works fine with regards to positioning. For example, a 10mm cut in Z axis is exactly 10mm, and the same with regard to X.
However, I cannot obtain the correct thread pitch, or maintain it if a different RPM is used.
For example,
If I wish to cut a 1.5mm pitch thread at 1000rpm, then the resulting pitch is much finer than 1.5mm
If I try again, but with a lower rpm, say 500, then the pitch is much more coarse.
The higher the RPM, then the finer the resultant pitch.
The start point of the thread is always maintained.
Encoder Position via HALshow indicates it is counting correctly per one rpm of motion.
Could this be a Latency problem?
02 Apr 2022 22:51 #239114 by cmorley
Replied by cmorley on topic G76 incorrect pitch
Could you tell us more about the hardware you are using?
Is there gearing between the motor and spindle?
Posting your config files could help too.
03 Apr 2022 09:36 #239141 by rider-83
Replied by rider-83 on topic G76 incorrect pitch
Gearing is 1:1
Encoder Position counts correctly after testing with multiple rotations.
Files attached
04 Apr 2022 07:02 #239225 by rider-83
To add the the above.
Ive run three tests with the same G76 program, each with differant RPM speeds but all with the same F1.5 pitch
The parts were measured on a Digital Shadowgraph:
1000 rpm = 0.8 Pitch
500 rpm = 1.5 Pitch
300 rpm = 1.5 Pitch
It would appear that it can't keep up after a certain RPM?
  • Moderator
  • Moderator
04 Apr 2022 12:23 #239240 by tommylight
Replied by tommylight on topic G76 incorrect pitch
You should have mentioned using a parallel port, and the encoder PPR, as that is a very limiting factor.
Set the servo period to 1000000 in the ini file and do not change that, it will mess up the PID loop if it is used anywhere.
As a rough guide, a base period of 100000 will do 10000 counts per second.
04 Apr 2022 18:46 #239272 by rider-83
I adjusted:
Servo to 1000000
Base to 100000
And I get the Latency Error. The lower I set the Base, the more frequent the error message.
If I set Base higher to 110000, then I get 'Joint 1 following error'
When I run 'Latency Test' via Terminal, I see Base Jitter around 10,5000
Do I have an under performing PC ?
  • Moderator
  • Moderator
04 Apr 2022 19:53 #239276 by tommylight
uname -a
If you have the 2.8.2 official ISO, there is a full how to on installing RTAI kernel that should provide better latency for use with parallel port:
linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI
You can switch between kernels at boot time, fi you do not see the GRUB menu, hold down the "shift" key after pressing the power button.
05 Apr 2022 18:12 - 05 Apr 2022 18:17 #239366 by rider-83
I have 2.8.2 installed
uname -a revealed:
4.19.0-14-rt-amd64 #1 SMP PREEMPT RT DEBIAN 4.19.171-2
Lantency Test revealed:
Running  glxgears + web browser + pdf viewer
Test 1 (on board graphics)
SERVO JITTER 39395
BASE JITTER 58168
INTERVAL MAX SERVO 1039395
INTERVAL MAX BASE 83168
Test 2 (PCIe 16 Graphics Card)
SERVO JITTER 66909
BASE JITTER 54364
INTERVAL MAX SERVO 1066909
INTERVAL MAX BASE 79364
Also, I have a recent problem. Ever since our new router arrived, I cannot connect the CNC Lathe to the network for updates :(
Last edit: 05 Apr 2022 18:17 by rider-83.
06 Apr 2022 19:06 - 06 Apr 2022 19:08 #239463 by rider-83
I seem to have cured the Latency error and Joint following problem by re-setting my driver boards to quarter turn, and adjusting the SCALE from 800 to 400.
However, when I feed with G1 the axis movement has become very slow. Rapids appear the same, and positioning is correct and accurate. What have I done wrong?
Also I have noticed if for example a set the feed to F0.25, then GMOCCAPY shows only 0.2 and so on.
.INI attached
Last edit: 06 Apr 2022 19:08 by rider-83.
07 Apr 2022 22:11 #239600 by andypugh
Replied by andypugh on topic G76 incorrect pitch
The slow G1 moves could be feed-override in the GUI.
Time to create page: 0.446 seconds
