Linuxcnc IDE
07 Apr 2022 17:47 - 08 Apr 2022 06:49 #239564 by udoS
Replied by udoS on topic Linuxcnc IDE
@Reinhard
Little help ?
for (int i = 0; i < NumGridRows; ++i)
m_buttonsName = ( "btn_" + QString::number(i) + "_toggled");   //btn_x_toggled
        m_buttons->setObjectName(m_buttonsName);
        m_buttons
->setCheckable(true);
        m_buttons
->setChecked(false);
        QObject::connect(m_buttons,SIGNAL(pressed()),this,SLOT(??????????()) );
How do I get that argument in ?
???      udoS
Last edit: 08 Apr 2022 06:49 by udoS.
08 Apr 2022 02:46 #239614 by Reinhard
Replied by Reinhard on topic Linuxcnc IDE
@udoS
Although this code is not my code, I'm willing to help, but I don't support lazyness!
You already know the class name and the method name - and your question is well documented. So rtfm!
08 Apr 2022 06:46 - 08 Apr 2022 06:50 #239622 by udoS
@Reinhard
Hi. I was almost expecting that much. Sorry.
I know what has to go into that field. Just can't figure it.
About that rtfm -- my eyes are bleeding already..
Last edit: 08 Apr 2022 06:50 by udoS.
08 Apr 2022 13:48 #239667 by Reinhard
Can't believe it!
If you search for "qt signals" one of the first entries leads you to this page .
Qt has many of such fundamental pages with lots of examples in it.
i would argue qt online docs are exemplary!
Not like many others where you can read a lot without understanding anything :(
09 Apr 2022 05:16 #239708 by udoS
I know what has to go inside the SLOT(?????(xxx)(yyy zzz))
I do not know how to ?? formulate it. :-((
05 May 2022 06:25 #242021 by udoS
@Reingard (or any one else of course)
Hi Reinhard, can I some how talk you into a project building the interface for LogicLabs PLC into LinuxCNC?
It's a Software-PLC with a Ethercat Master and other Interfaces.
Professional. Not the way I would/could do it. :-(
www.axelsoftware.it/en/runtime-components/
Best Regards
06 May 2022 02:22 - 06 May 2022 02:25 #242099 by smc.collins
Replied by smc.collins on topic Linuxcnc IDE
QT C++ absolutely kills Python in any heavy computational workloads though, as does just plain C++, that's not specifically a QT thing, it's a c/c++ thing. My big beef with Python, is that it is executionaly inefficient in every benchmark I have ever seen.
Last edit: 06 May 2022 02:25 by smc.collins.
14 Jul 2022 13:57 - 14 Jul 2022 14:06 #247289 by udoS
@Reinhard      Off Topic;
Reinhard, I'm looking for the joint.n.vel-cmd over nml chanal;
I think you have been all over it, so is there a emcstat for it.
I couldn't find it in your
github.com/DjangoReinhard/FalconView
Best regards
Last edit: 14 Jul 2022 14:06 by udoS.
14 Jul 2022 15:13 #247298 by Reinhard
Learn how to use grep and don't search for linuxcnc items in my project!
Go to source-tree of linuxcnc and issue some grep -R "whatever-u-search-4"
If you don't know the exact casing of your search pattern use grep -Ri "..."
lowercase-i stands for "ignorecase".
15 Jul 2022 06:03 #247354 by udoS
@Reinhart ... thanks; that was easy;
Now in your FalconView git you say :sample directory contains two cmake files indispensable for successful build:
  • FalconView.cmake
  • FindlinuxCNC.cmake
There is a FindlinuxCNC.cmake ;
But there is NO FalconView.cmake ; ?
Time to create page: 0.413 seconds
