Exceeding limits for no reason
4 years 6 months ago #239800 by rodw
I am really confused here.
So confused in fact I don't know where to post this
This is only my second milling job and I am getting unexplainable errors about the program exceeding limits before the job runs.
I deleted everything except a single drilling operation. All motion is within the limits and the error persists.
All X,Y moves work from the MDI
What could be causing this?
I am at a total loss.
I just saw a G43 and commented it out and it made no diference but I cant see how the  Y axis is affected
Hal and ini and ngc files are attached.
File Name: VMNmill.hal
File Size:5.89 KB
File Name: VMNmill.ini
File Size:3.96 KB
File Name: JigBasethr...rill.ngc
File Size:1.13 KB
4 years 6 months ago #239801 by robertspark
why does joint 1 say
HOME_IGNORE_LIMITS = NO
when the other 2 were set to yes?
4 years 6 months ago - 4 years 6 months ago #239802 by robertspark
how is that going to work with your Y axis limits?
G0 X22. Y-61.
[AXIS_Y]MIN_LIMIT = -1MAX_LIMIT = 140
(are you moving your work coordinates (have you applied an offset somewhere, or are your machine and work coordinates aligned??)
Last edit: 4 years 6 months ago by robertspark.
4 years 6 months ago #239804 by rodw
Replied by rodw on topic Exceeding limits for no reason
yeh have touched off to G54.
Home 0,0 is bottom left facing the table
But I can touch off at the hole location and delete the move to 22,-61 and I still get y error when there is no y movement
but in the mdi I can g0 x402 y -126
so nothing makes sense...
Could tool table data cause this?
4 years 6 months ago #239819 by robertspark
I clutching at straws...
TOOL_CHANGE_POSITION = 0 0 50.8
X = 0, Y =0, z= 50.8 (2".....)
z machine coordinate limits....
[AXIS_Z]
MIN_LIMIT = -138.1
MAX_LIMIT = 0.001
[JOINT_2]
MIN_LIMIT = -138.1
MAX_LIMIT = 0.001
what are your tool length offsets, are they negative?
4 years 6 months ago #239821 by rodw
Yes, I suspect its to do with the tool library. Some earlier code that worked for me did not have TX M6 in it
