LinuxCNC 2.7.15 won't load any more.
  • muzza
  • muzza's Avatar Topic Author
  • Senior Member
  • Senior Member
24 Apr 2022 14:50 - 24 Apr 2022 15:01 #241069 by muzza
I moved the HDD to a 'new' computer and I get an error, such as
'UNEXPECTED INCONSISTENCY'
'fsck died with exit status 4'
The last line of the error says; 'sulogin: root account is locked, starting shell'
The command line then chuggs along for quite some time (see 2nd photo)... something regarding the mouse and this goes on for something like 19 times.  I reboot when it's finished (ctrl d) and when it reboots, the whole thing starts over again.
Other HDDs boot fine (Windoze 7 and LCNC 2.8.2 rtai Buster)
(btw, 2.8.2 Buster loads fine, but I have not yet got a working config.  But that's another question. 2.7.15 WAS working)
Last edit: 24 Apr 2022 15:01 by muzza. Reason: second image didn't load
  • Moderator
  • Moderator
24 Apr 2022 15:07 #241071 by tommylight
Replied by tommylight on topic LinuxCNC 2.7.15 won't load any more.
Set the date and time in BIOS, then when it gets to that screen:
fsck -y /dev/sda
The following user(s) said Thank You: muzza
  • muzza
  • Senior Member
  • Senior Member
24 Apr 2022 15:56 #241075 by muzza
Replied by muzza on topic LinuxCNC 2.7.15 won't load any more.
Thanks Tommylight.
I'll try that tomorrow.
  • muzza
  • Senior Member
  • Senior Member
25 Apr 2022 01:40 #241134 by muzza
I replaced the cmos battery, changed the date and it booted up properly.
Cheers
Time to create page: 0.105 seconds
