mesa 7i96
26 Apr 2022 09:30 #241269 by rohit269
mesa 7i96 was created by rohit269
Sir,
I am configure mesa 7i96 (LinuxCNC 2.8.0 Debian 7 Wheezy RTAI) in linuxcnc pincconf wizard after completing wizard after than i start it than i found error LinuxCNC_machine_mill.hal:9: Can't find module 'hm2_eth' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
12490
a
please tell how solve this problem
26 Apr 2022 09:34 #241271 by rodw
Replied by rodw on topic mesa 7i96
Mesa ethernet cards require PREEMPT_RT kernel. DO you have it?
26 Apr 2022 09:46 #241272 by rohit269
Replied by rohit269 on topic mesa 7i96
Thanks for reply,
Sir,
LinuxCNC 2.8.0 Debian 7 Wheezy RTAI cannot run mesa 7i96 card
26 Apr 2022 10:02 #241273 by my1987toyota
Replied by my1987toyota on topic mesa 7i96
You may consider updating to the current iso. of Debian Buster with Linuxcnc . Put it on a separate drive so if you don't like the result you can revert
back to the old system.  I believe the default Linuxcnc kernel is PREEMPT_RT .
26 Apr 2022 18:49 #241321 by rohit269
Thanks for you answer.
26 Apr 2022 20:35 #241329 by rodw
Yes it is.
You will need to update to the latest ISO which is based on Buster
Time to create page: 0.121 seconds
