G code question when running autolevel
- kenwoodhf
- Topic Author
4 years 6 months ago #241325
by kenwoodhf
G code question when running autolevel was created by kenwoodhf
I am running LinuxCNC 2.8.2.11 and Autolevel 0.8.7
I get a error when I load a autolevel file
Near line 281 of..........AL6X6.ngc
Unknown word unary operation could be
N11 Z0.118
#102=#500
#101=#500
#100=[#102+NaN*#101-NaN*#102]
N12 G1Z[#100 + -0.1] F3.937 (this is Line 281)
#102=#500
#101=[#500+0*#507-0*#500]
#100=[#102+0*#101-0*#102]
N16 X0Y0 Z[#100 + -0.1]
#102=[#500+0*#507-0*#500]
#101=[#501+0*#508-0*#501]
#100=[#102+0.187*#101-0.187*#102]
N13 X0.187Y0 Z[#100 + -0.1] F20
I do not understand what the line is trying to tell me or how to change it.
Any help would be welcome
Jan
N11 Z0.118
#102=#500
#101=#500
#102=#500
Jan
- MaHa
- Thank you received: 192
4 years 6 months ago - 4 years 6 months ago #241330
by MaHa
Replied by MaHa on topic G code question when running autolevel
This Line is highly suspicious, containing unknown gcode
Last edit: 4 years 6 months ago by MaHa.
4 years 6 months ago #241338
there is a + and a - in front of 0.1, not sure if that is the issue but never seen both signs in a value for gcode.
Replied by tommylight on topic G code question when running autolevel
- kenwoodhf
- Topic Author
4 years 6 months ago #241342
by kenwoodhf
Replied by kenwoodhf on topic G code question when running autolevel
Thanks for the comment
-0.1 is the Z depth of the cut in the program. I assume the line means #100 plus -0.1. but I am maybe just guessing
Jan
Jan
- kenwoodhf
- Topic Author
4 years 6 months ago #241344
by kenwoodhf
Thanks for the reply
I have no idea what NaN even means but it only shows up once in 816 line program.
Jan
Jan
4 years 6 months ago #241345
Just a stab in the dark:
NaN = Not a Number ???
- kenwoodhf
- Topic Author
4 years 6 months ago #241387
by kenwoodhf
You could be right. I don't know why this line came up but it doesn't when I load other autolevel files. Must be a quirk in this file. I did delete the line and the program seemed to run fine.
Thanks again
Jan
Thanks again
Jan
- Thank you received: 2620
4 years 6 months ago #241585
Replied by andypugh on topic G code question when running autolevel
NaN is, indeed "Not a Number". It's a specific value in IEEE floating point:
en.wikipedia.org/wiki/NaN
It is an interesting thing. For example NaN = NaN is false.
That's probably more than you need to know, but it is generally the result of a divide-by-zero. It seems that autoleveller is parsing NaN into G-code strings in such a way that NaN becomes the string "NaN". It really ought to either error out, or put a zero in. Or something else.
Time to create page: 0.271 seconds
