Random exception in Tkinter callback, out of memory
- NotAllThere
30 Apr 2022 22:42 - 30 Apr 2022 22:47 #241744
by NotAllThere
Random exception in Tkinter callback, out of memory was created by NotAllThere
Newbie with a PC with LinuxCNC 2.8.2 with 6GB RAM and a Mesa 7i76e board connected to a Chinese 6040. It worked great for several months, but now after say 20-30 minutes, LinuxCNC crashes with the error:
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1550, in __call__
return self.func(*args)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 599, in callit
func(*args)
File "/usr/bin/axis", line 560, in actual_tkRedraw
self.tkRedraw_perspective()
File "/usr/bin/axis", line 520, in tkRedraw_perspective
self.redraw_perspective()
File "/usr/lib/python2.7/dist-packages/rs274/glcanon.py", line 352, in inner
return f(self, *args, **kw)
File "/usr/lib/python2.7/dist-packages/rs274/glcanon.py", line 599, in redraw_perspective
glFlush() # Tidy up
error: (1285, 'out of memory')When I run "top" in a terminal window, there is about 4GB free when it crashes. Error report, ini and hal files attached. Like I said, I'm new at this so feel free to point out if I've made poor choices in the configurations.
Thank you for any assistance you can provide. I can't wait to get this running reliably and start configuring the rotary axis.
Ted
Last edit: 30 Apr 2022 22:47 by NotAllThere. Reason: Cleaned up error text formatting again
- Thank you received: 7488
01 May 2022 00:43 #241755
Replied by tommylight on topic Random exception in Tkinter callback, out of memory
Seems like something with the OpenGL subsystem is wrong, or maybe Python as the calls are from it.
Did you upgrade or install anything?
Do you have add on graphic card? or if the PC has one, try removing it and using the on board graphics.
- NotAllThere
02 May 2022 18:25 #241863
by NotAllThere
Replied by NotAllThere on topic Random exception in Tkinter callback, out of memory
Thank you for taking the time to point me in the right direction. No upgades or add-on cards, just an old stock HP. But, it did have an integrated GeForce video chipset and once I found the correct drivers, it seems to have fixed the problem. I'm not sure what triggered the problem since it has been running for some time, but so far, so good.
Thanks again. Now off to figure out my 4th axis...
Ted
Ted
Time to create page: 0.083 seconds
