Laser head with 10 laser diodes
- Gus71
18 May 2022 05:16 #243245
by Gus71
Replied by Gus71 on topic Laser head with 10 laser diodes
the following G codes are active.
G1 G8 G17 G21 G40 G49 G54 G64 G90 G91.1 G94 G97 G99
Yes, G64 is also there.. What does that tell me?
- Gus71
18 May 2022 05:23 #243246
by Gus71
G61 is not active! do i have to do something?
because the M commands toggle on and off and the axis doesn't stop, it works
- Thank you received: 4652
18 May 2022 07:51 #243252
I don't know if you can easily view the G64 tolerance number.
If it is working now, then just file the knowledge away.
Note that M62 / M63 do not execute until the next motion command. To turn the laser off at the end of the code you should either add a dummy motion to the same position or use M64 / M65 as those do not wait for motion.
Replied by andypugh on topic Laser head with 10 laser diodes
Only really that you are not in G61 or G61.1 mode. (Which would have explained the problem)the following G codes are active.
- Thank you received: 1472
18 May 2022 15:15 - 18 May 2022 15:16 #243276
Replied by Todd Zuercher on topic Laser head with 10 laser diodes
I did some testing and if M62/M63 are on the same line as a motion command, they are executed at the beginning of that move. See the below commented G-code.
And I double checked it with Halscope.
g64p0.01
g0x0
g1x1m62p1f300 (digital-out-01 turns on at begining of move to x1 at position x=0)
x2x3m63p1 (digital-out-01 turns off at x=2)
x4
x5m62p1 (digital-out-01 turns on at x=4)
x6m63p1 (digital-out-01 turns off at x=5)
m62p1 (digital-out-01 turns on at x=6)
m62p0 (digital-out-00 turns on at x=6)
m62p2 (digital-out-02 turns on at x=6)
x7
m63p0 (digital-out-00 turns off at x=7)
x8
m63p1 (digital-out-01 turns off at x=8)
x9
m63p2 (digital-out-02 turns off at x=9)
g0x0
m2And I double checked it with Halscope.
Last edit: 18 May 2022 15:16 by Todd Zuercher.
Time to create page: 0.135 seconds
