Wiring of servo spindle - MESA 7i76E
10 Jun 2022 12:08 #244865
linuxcnc.org/docs/stable/html/man/man1/halui.1.html
I would start by looking to see if motion.motion-enabled has the desired behaviour:
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
That's from the motion module, and should be 100% reliable even if the GUI crashes.
You can use halmeter to watch how pins change state.
linuxcnc.org/docs/stable/html/hal/tools.html#_halmeter
You might also need:
linuxcnc.org/docs/stable/html/man/man9/estop_latch.9.html
Replied by andypugh on topic Wiring of servo spindle - MESA 7i76E
Possibly halui.estop.is-activated but that is from halui so not real-time.
- What is the typical fault signal called within Linux CNC that would be good to trigger the physical e-stop loop?
- linuxcnc4less
14 Oct 2024 02:34 #312025
by linuxcnc4less
Replied by linuxcnc4less on topic Wiring of servo spindle - MESA 7i76E
Time to create page: 0.111 seconds
