Network issue wifi will not connect
  • Kasper-001
  • Kasper-001's Avatar Topic Author
  • Premium Member
  • Premium Member
22 May 2022 09:10 #243538 by Kasper-001
Network issue wifi will not connect was created by Kasper-001
hello im trying to connect to my wifi network, whit a TP dongle on my linux machine
my security protocol is WPA2 on the router
cnc@debian:~$ sudo iwconfig
[sudo] adgangskode for cnc:
eno3      no wireless extensions.
lo        no wireless extensions.
eno2      no wireless extensions.
eno1      no wireless extensions.
wlxb4b024bdd233  IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Encryption key:off
          Power Management:off
eno4      no wireless extensions.
cnc@debian:~$ sudo iwlist wlxb4b024bdd233 scan | grep ESSID
                    ESSID:"BIOMAX"
                    ESSID:"KapperDK-2.4G"
cnc@debian:~$ wpa_passphrase KapperDK-2.4G ********* | sudo tee -a /etc/wpa_supplicant/wpa_supplicant.conf
network={
    ssid="KapperDK-2.4G"
    #psk="***********"
    psk=d506f2ead96348ce8af89445dbff98d8ce70a4d322bb448a106561cee23730ae
cnc@debian:~$ sudo wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -i wlxb4b024bdd233
Successfully initialized wpa_supplicant
wlxb4b024bdd233: SME: Trying to authenticate with 68:ff:7b:96:ee:c9 (SSID='KapperDK-2.4G' freq=2452 MHz)
wlxb4b024bdd233: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="KapperDK-2.4G" auth_failures=1 duration=10 reason=CONN_FAILED
wlxb4b024bdd233: CTRL-EVENT-SSID-TEMP-DISABLED id=1 ssid="KapperDK-2.4G" auth_failures=1 duration=10 reason=CONN_FAILED
^Cnl80211: deinit ifname=wlxb4b024bdd233 disabled_11b_rates=0
wlxb4b024bdd233: CTRL-EVENT-TERMINATING
  • Moderator
  • Moderator
22 May 2022 12:06 #243550 by tommylight
Replied by tommylight on topic Network issue wifi will not connect
What Linux distro?
  • Kasper-001
  • Premium Member
  • Premium Member
22 May 2022 18:48 #243567 by Kasper-001
Replied by Kasper-001 on topic Network issue wifi will not connect
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
23 May 2022 22:24 #243648 by andypugh
Replied by andypugh on topic Network issue wifi will not connect
Some dongles are simply unsupported by Linux (I have one) but that does not seem to be the issue here.
Is the network using the security method that you think it is? (ie, WPA)
  • Kasper-001
  • Premium Member
  • Premium Member
30 May 2022 18:17 #244237 by Kasper-001
it is wpa, but i´ll just stay on cable :)
