Can I specify which directory it starts at to Open a file?
4 years 5 months ago #243557 by dannym
Right now any time you hit Open to load a gcode file, it starts from the LinuxCNC install directory, and you need to drop several levels on the tree and then up one to media/username and whatever USB drive is inserted.  It's very repetitive.  Can I specify to start there instead?
I'm using AXIS.
4 years 5 months ago #243570 by tommylight
In the .ini file, section "display" enter this
OPEN_FILE = name of the file
File must be in the config folder, or a full path to it must be entered.
ASUS ROG Crosshair VIII Impact - AMD X570
4 years 5 months ago #243579 by FariaAl
in my case this works for me:
in the .ini file, section "DISPLAY", add
PROGRAM_PREFIX = home/USER/Projects_Gcode
change "USER" to match your machine.
4 years 5 months ago #243606 by BigJohnT
In the {DISPLAY] section you can use ~/ shortcut to the users home directory.
PROGRAM_PREFIX = ~/Desktop
JT
4 years 5 months ago - 4 years 5 months ago #243812 by dannym
PROGRAM_PREFIX= did it, thanks!
Last edit: 4 years 5 months ago by dannym.
Time to create page: 0.325 seconds
