No parport registered
- marceloBrazil
30 May 2022 11:38 #244227
by marceloBrazil
No parport registered was created by marceloBrazil
Hello friends!
I had a machine running linuxcnc normally.
I use the version LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO
I went to change the motherboard and parallel port and now it prints the following message
no parport registered at 0xe000
lspci shows the following parallel port:
lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation H61 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 Serial controller: Asix Electronics Corporation Device 9100
01:00.1 Serial controller: Asix Electronics Corporation Device 9100
01:00.2 Parallel controller: Asix Electronics Corporation Device 9100
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 05)
lspci -vv shows the following parallel port:
01:00.0 Serial controller: Asix Electronics Corporation Device 9100 (prog-if 02 [16550])
Subsystem: Device a000:1000
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at e030
Region 1: Memory at f7c05000 (32-bit, non-prefetchable) [size=4K]
Region 5: Memory at f7c04000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
01:00.1 Serial controller: Asix Electronics Corporation Device 9100 (prog-if 02 [16550])
Interrupt: pin B routed to IRQ 17
Region 0: I/O ports at e020
Region 1: Memory at f7c03000 (32-bit, non-prefetchable) [size=4K]
Region 5: Memory at f7c02000 (32-bit, non-prefetchable) [size=4K]
01:00.2 Parallel controller: Asix Electronics Corporation Device 9100 (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin C routed to IRQ 3
Region 0: I/O ports at e010
Region 1: I/O ports at e000
Region 2: Memory at f7c01000 (32-bit, non-prefetchable) [size=4K]
Region 5: Memory at f7c00000 (32-bit, non-prefetchable) [size=4K]
My HAL-File is the following:
# Generated by stepconf 1.1 at Fri May 27 13:51:13 2022
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xe010 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
tried as two separate ports to no avail:
loadrt hal_parport cfg="0xe000 out"
proc command returns nothing
cat /proc/ioports|grep parport*
need help.
thanks
lspci
need help.
thanks
- Thank you received: 7504
30 May 2022 12:22 #244233
Replied by tommylight on topic No parport registered
Get the card out, give it a good clean on the pins with a cotton ... t shirt or towel, get a toothbrush and clean the pins inside the slot on the motherboard, put the card back in.
Or just try another slot, if there are any.
- Bari
- Thank you received: 234
30 May 2022 20:47 - 31 May 2022 21:06 #244256
by Bari
Replied by Bari on topic No parport registered
I saw this problem, a week or two ago on IRC.
Which make and model card is this?
forum.linuxcnc.org/27-driver-boards/3439...l-cards-what-chipset
@marceloBrazil Can you try lspci -vv as root or sudo and post the relevant output?
I think it's some newer non-standard chip used or clone device.
Last edit: 31 May 2022 21:06 by Bari.
- Bari
24 Jul 2022 18:00 - 24 Jul 2022 18:13 #248198
by Bari
PCIe MCS9900 strangeness: Capabilities: <access denied> Saw this helping someone with the same card a few months ago on IRC.
LCNC 2.9 Stepconf does not recognize the card either.
Linux lcncbull 5.18.0-0.bpo.1-rt-amd64 #1 SMP PREEMPT_RT Debian 5.18.2-1~bpo11+1 (2022-06-14) x86_64 GNU/Linux
2:00.0 Parallel controller: MosChip Semiconductor Technology Ltd. MCS9900 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Asix Electronics Corporation (Wrong ID) MCS9900 Multi-I/O Controller
Flags: bus master, fast devsel, latency 0, IRQ 5, NUMA node 0
I/O ports at df00
I/O ports at de00
Memory at fdcff000 (32-bit, non-prefetchable)
=4K%Memory at fdcfe000 (32-bit, non-prefetchable)
=4K%Capabilities: <access denied>
I/O ports at df00
I/O ports at de00
- 02:00.0 Parallel controller [0701]: MosChip Semiconductor Technology Ltd. MCS9900 Multi-I/O Controller [9710:9900] (prog-if 03 [IEEE1284])
- Subsystem: Asix Electronics Corporation (Wrong ID) MCS9900 Multi-I/O Controller [a000:2000]
- Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
- Latency: 0, Cache Line Size: 4 bytes
- Interrupt: pin A routed to IRQ 5
- NUMA node: 0
- Region 0: I/O ports at df00
- Region 1: I/O ports at de00
- Region 2: Memory at fdcff000 (32-bit, non-prefetchable) [size=4K]
- Region 5: Memory at fdcfe000 (32-bit, non-prefetchable) [size=4K]
- Capabilities: <access denied>
Last edit: 24 Jul 2022 18:13 by Bari. Reason: more lspci
24 Jul 2022 19:41 #248211
Use sudo for lspci:"access denied" is the result of not using sudo.
some ports will not work when set to 0 or 1 in LinuxCNC so they do need the exact address, in Bari's case it is 0xdf00 or 0xde00, this can be entered in StepConf or edited in hal.
For MarceloBrasil it would be 0xe010 or 0xe000.
Please be aware that if one of the addresses do not work, restart the PC as it might keep the port locked and not work even after entering the correct address.
sudo lspci-
- Bari
24 Jul 2022 19:58 #248212
by Bari
The better fix will be adding these PCI addresses to the kernel.
I'm sorry but when you dumb down the LPT ports to 0 and 1 how do you know which one is which when you have 2 LPT ports without trial and error?
StepConf did not let me edit the LPT port when it could not find a LPT port.
- Bari
03 Oct 2022 21:01 #253408
by Bari
github.com/LinuxCNC/linuxcnc/issues/2055
revert: Removed the option of manually inserting the parallel port
Is fixed now! \0/
Is fixed now! \0/
Time to create page: 0.653 seconds
