Mesa card selection help
4 years 5 months ago #244278 by anders
I am retrofitting my Emco F1P and decided to use LinuxCNC. First I tried to dry run everything using cheap steppers/drivers and a simple generic LPT BOB. I quickly noticed that I could not generate steps fast enough using only the PC so I started looking into Mesa Cards. There are a lot of cards to choose from...
Basically what I want to do is to run my three axis (possibly a fourth) steppers (plus endstops etc) and maybe in the future add scales to the different axis like MetalMusings did on his machine on YouTube.
It seems like the best way to go is to use an Ethernet based interface.
Any suggestions on a Mesa card that would fulfill my needs would be very much appreciated!
If somebody has done a similar or the same retrofit any info on steppers and the driver used would be helpful too.
Thanks!
 Anders
4 years 5 months ago - 4 years 5 months ago #244288 by tommylight
Replied by tommylight on topic Mesa card selection help
Mesa 7i95 can do everything you might need now and in the future:
store.mesanet.com/index.php?route=produc...oduct&product_id=343
Also, Mesa 7i96 or 7i76E depending on the starting budget or availability.
All of them can be expanded at any time with SSerial or daughter cards for even more functionality.
Edit:
see:
www.mesanet.com
www.mesaus.com
www.eusurplus.com
Last edit: 4 years 5 months ago by tommylight. Reason: more info
The following user(s) said Thank You: anders
3 years 1 month ago #279935 by masawee
Replied by masawee on topic Mesa card selection help
what different have 7i96 E or T or S card, and what id different 7i96 or 7i76 card, i not understand, need found cheapen possiple mesa card to my old pc. 4-5 axis need and lot input more than old cheap 10$ paraller port card.maybe future adding axis screw top encoders. i not understand what different all cards have, 96S or 76 e and proto D version
were found cheapen 96S card. all have very expensive cards if think paraller card cost only 10$
3 years 1 month ago #279950 by tommylight
Mesa 7i96S + 7i84 = 5 axis, spindle, 11+32 inputs, 6+16 outputs.
3 years 1 month ago #280451 by Tech3
Replied by Tech3 on topic Mesa card selection help
I am looking to develop a cnc project related to linuxcnc with Mesa motion control board ( like 7i96S and 7i76E). You had mentioned in the previous mail related to Mesa 7i96S + 7i84. I'm also having a plan to do that. As far as I understand, I need to get a daughter card for the extra inputs and outputs. However, I am a bit lost which daughter cards are compatible for both 7i76E 7i96S.Can you pls ping me.
3 years 1 month ago #280471 by tommylight
7i76E and 7i96S are FPGA boards, 7i84 is a smart serial (remote) board.
7i84 can be used with both, but not at the same time.
No need for any other card.
How do you want me to ping you?
Time to create page: 0.062 seconds
