Axis jog issue
04 Jun 2022 07:53 #244562 by Yannis
Axis jog issue was created by Yannis
  Hello
i create a 4 axis machine and manually try to make it 5 axis X Y Z C B I have this probem : When i try to jog the machine i can move the X Y Z axis normaly i can move B axis in positive direction but i can not move B axis in negative direction an C axis in both directions
when i hit the button in this 3 directions the velocity value change,
in the DRO the value stay at 0
(suspect that i dint connect the signals correct)
Any suggestions?…
File Name: AGISANDROS.ini
File Size:5 KB
File Name: AGISANDROS.hal
File Size:14 KB
07 Jun 2022 22:37 #244739 by BigJohnT
Replied by BigJohnT on topic Axis jog issue
You might want to try my Mesa Configuration Tool.
gnipsel.com/mesa/mesact/index.html
JT
The following user(s) said Thank You: Yannis
