-For a grown-up industrial (or serious hobby) lathe with a q/c gearbox that has both a leadscrew as well as a shaft-driven power feed, an ELS is generally a waste of time.
However, for small hobby lathes which are typically driven only by a leadscrew and may still have individual change-gears, an ELS is a godsend. Imagine having to switch out gears just to go from a roughing to finishing chipload? Very time consuming and annoying.
On one hand, you could ask what's the point? Why not just CNC the thing? The answer is - no significant hardware changes, very low cost (compared to a full X/Z retrofit with ballscrews), and very easy interface. No new 'language' to learn, no program to write.
If all you have is a small lathe that is annoying to use, an ELS can be a game-changer.
