LinuxCNC as ELS for lathe?
4 years 4 months ago #244800 by spumco
Replied by spumco on topic LinuxCNC as ELS for lathe?
I'm not an expert by any stretch in LCNC, but I can think of a couple ways of using LCNC for this.  But a dedicated ELS is likely simpler, assuming you can borrow someone else's design and microcontroller program.
And creating a user interface for LCNC will be a challenge if you've never done a GUI before.
The following user(s) said Thank You: Markyd
4 years 4 months ago #244803 by Todd Zuercher
Considering the only difference between doing an ELS and full CNC control in Linuxcnc is one stepmotor. What's the point of only doing it half way?
4 years 4 months ago #244804 by spumco
Perhaps someone simply wants a manual lathe and not a CNC lathe, but they want the ability to cut many different threads or feed-rates.
I think of them as enhancing a manual lathe rather than being a half-a$$ CNC lathe.  Like a power down-feed on a mill quill - not necessary, but makes a huge difference in user experience.
4 years 4 months ago #244810 by Todd Zuercher
Just because you add cnc capability doesn't mean it has to loose the ability to be used manually.
I certainly would want to keep manual capabilities on a lathe, if I were ever to convert one.
4 years 4 months ago #245029 by andypugh
Replied by andypugh on topic LinuxCNC as ELS for lathe?
No eBay APP ID and/or Cert ID defined in Kunena configurationBasically, the ELS requires a way to set the TPI / mm pitch.
You can certainly do this with LinuxCNC, and the fact that LinuxCNC has all the drivers might be a good enough reason.
I have always fancied doing an ELS with BCD switches (eg ) and a metric/imperial switch. That way you could run the Pi without a display and run a non-gui non-g-code HAL-only config.
I would probably write a custom component for the job, rather than glue together all the required existing modules, but it certainly could be done with standard HAL modules.
I think three digits is probably enough for most purposes? 1 to 999 TPI and 0.01 to 9.99 mm pitch.
Then you would need 4 IO pins per digit + units. so 13 inputs. Unfortunately the 7i96 only has 11 inputs, so this scheme would maybe have to use a scale of 0.01 to 3.99 mm and 1 to 399 TPI.
(though you could use the Pi built-in GPIO for the inputs instead of / as well as the 7i96.
Time to create page: 0.257 seconds
