Analog Output M68 on Mesa 7C80
- luki
09 Jun 2022 09:20 #244796
by luki
Analog Output M68 on Mesa 7C80 was created by luki
Dear Community,
I have a Mesa 7c80 with RPi4 and I want to output an Analog Signal from GCode
My Mesa Card has a digital potentiometer on board. So I will hook +5V to Spindle+ and GND to Spindle-
My plan is to control the voltage coming out from Spindle Out.
What do I have to configure in INI and HAL to control that digital potentiometer by M68 in GCode ?
I added something like:
motion.analog-out-00 => hm2_7c80.0.pwmgen.00.value
but LinuxCNC won't accept that. What am I doing wrong?
- luki
09 Jun 2022 11:09 #244798
by luki
Replied by luki on topic Analog Output M68 on Mesa 7C80
Ok. I think it works now...
what I did:
setp [HMOT](CARD0).pwmgen.00.enable 1 Enables the PWM-Generator (Important!)
setp [HMOT](CARD0).pwmgen.00.scale 200 Sets the scale to 200
setp [HMOT](CARD0).pwmgen.00.out0.invert_output 1 Inverts the output
net XXX motion.analog-out-00 => [HMOT](CARD0).pwmgen.00.value XXX can be anything
As a remainder: So I hooked up +5V to Spindle+ and GND to Spindle-
Now when I write GCode:
M68 E0 Q200 spindleOut will be 5 Volts
and with
M68 E0 Q100 spindleOut will be 2,5 Volts
Hope this helps anyone.
what I did:
and with
The following user(s) said Thank You: andypugh, rdtsc
Time to create page: 0.504 seconds
