G10 L2 Rotation for lathe?
- Eyecon
- Thank you received: 17
16 Jun 2022 22:55 #245290
by Eyecon
G10 L2 Rotation for lathe? was created by Eyecon
Hello,
is it possible rotate a WCS around the Y axis for a Linuxcnc setup in lathe mode?
- Thank you received: 2175
17 Jun 2022 01:00 #245293
Replied by cmorley on topic G10 L2 Rotation for lathe?
Yes and no.
there is a hacky way to do it by defining a Y joint/axis in the INI.
You get an warning message in the terminal but then you can use G10l2 to rotate around Y
- Eyecon
17 Jun 2022 05:51 #245304
by Eyecon
Replied by Eyecon on topic G10 L2 Rotation for lathe?
I can live with hacky
What I don't understand is how to change the behaviour of G10 L2 for Y axis rotation, my understanding is that it rotates around the Z axis by default.
17 Jun 2022 16:09 #245332
I'm sorry I guess i didn't read your request properly.
you are right you can only rotate around Z - I was thinking you wanted to mirror the X axis
- Eyecon
17 Jun 2022 18:37 #245340
by Eyecon
no worries, the idea was to do chamfers/tappers in a way similar to how a compound slide works but it's no big deal it can be done in other ways in G-code and some math.
Time to create page: 0.458 seconds
