PWM Spindle speed control
- Sabryxd
25 Jun 2022 21:30 - 25 Jun 2022 21:30 #245879
by Sabryxd
PWM Spindle speed control was created by Sabryxd
I am trying to control the spindle speed from the software I am using a 300w spindle that uses 36v power supply.
So I am planning to us the PWM spindle pin to have 0-5v to control the power supply's voltage hence controlling the spindle speed
The question is how do I implement and Are there any additional hardware required.
Any help is appreciated. <3
Last edit: 25 Jun 2022 21:30 by Sabryxd.
- Thank you received: 7463
25 Jun 2022 21:40 #245881
Replied by tommylight on topic PWM Spindle speed control
If you are referring to those spindles with SMPS power supplies and a potentiometer for speed control, then yes, you do need other hardware to isolate that power supply from the controller.
Some controllers and some BOB's do come with the hardware required, so nothing more is needed.
More info on what controller you are planing to use.
- Sabryxd
26 Jun 2022 05:16 #245900
by Sabryxd
Replied by Sabryxd on topic PWM Spindle speed control
I've got one of these
www.vallder.com/en/c/cnc-pc-cards/mach3-5-axis-board-detail
- Thank you received: 4648
28 Jun 2022 22:10 #246113
Replied by andypugh on topic PWM Spindle speed control
Looks good "Output 0-10V analog voltage for inverter to control the spindle speed."
It looks like it expects a PWM signal on DB25 pin 1. Stepconf should be able to configure that for you.
Also note that the BoB needs a 12V supply to the analogue output stage to become the output voltage.
Time to create page: 0.181 seconds
