zoom or scale router job
- rajsekhar
- Thank you received: 12
02 Jul 2022 01:47 #246411
by rajsekhar
zoom or scale router job was created by rajsekhar
I am running a router for design work.
Now situation arises that same design is to be done in different sizes. Is there any feature in LinuxCNC so that the original gcode may be scaled to my desired size?
- Thank you received: 7463
02 Jul 2022 08:59 - 02 Jul 2022 08:59 #246424
Replied by tommylight on topic zoom or scale router job
You gave no info on what CAM you are using.
Inkscape has an option to output parametric gcode, meaning changing the size and depth is as simple as editing the resulting gcode to change the XY or Z multiplier.
Check if your CAM has that option.
Last edit: 02 Jul 2022 08:59 by tommylight. Reason: typo
- rajsekhar
02 Jul 2022 12:18 #246435
by rajsekhar
Replied by rajsekhar on topic zoom or scale router job
I am using sheetcam at present. Also Artcam I have, although never tried till date.
- Thank you received: 4648
03 Jul 2022 10:28 - 03 Jul 2022 10:29 #246494
Replied by andypugh on topic zoom or scale router job
Last edit: 03 Jul 2022 10:29 by andypugh.
