What is the speed of M66
- beefy
- Thank you received: 58
03 Jul 2022 06:07 - 03 Jul 2022 06:23 #246478
by beefy
What is the speed of M66 was created by beefy
M66 is used to wait for an input to change state.
In the documentation is says:
In LinuxCNC these inputs are not monitored in real time and thus should not be used for timing-critical applications.
Would "real time" be classed as base-thread speed ??
Would M66 typically run at servo-thread speed, say a 1 Khz loop ??
I see M66 is part of the motion module which is set up in hal with:
loadrt motmod [base_period_nsec=period] [base_thread_fp=0 or 1] [servo_period_nsec=period] [traj_period_nsec=period] [num_joints=[1-9]] [num_dio=[1-64]] [num_aio=[1-64]] [num_spindles=[1-8]] [unlock_joints_mask=jointmask]
So would:
determine how fast M66 would monitor the pin state.
So would:
Last edit: 03 Jul 2022 06:23 by beefy.
- Thank you received: 4648
03 Jul 2022 11:09 #246502
Replied by andypugh on topic What is the speed of M66
I am somewhat puzzled by the statement, I actually did think that M66 was sampled at the servo-thread rate. (not base thread)
- beefy
03 Jul 2022 20:10 #246534
by beefy
Replied by beefy on topic What is the speed of M66
Cheers Andy.
Guess I'll just have to hook up a logic analyser and do some testing to check for repeatability of timing on physical I/O.
It's a bit frustrating when the docs tell you what it isn't and not what it is LOL.
Might be better doing this type of thing in Classicladder which I believe runs at servo thread rate. Can hopefully get 1 millisecond loop cycle.
Keith
Keith
