Gantry and Gmoccapy
  • Ingo
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #246625 by Ingo
Gantry and Gmoccapy was created by Ingo
Hello guys,
I'm going to start a machine project in which I will have two sets of servo and motor drivers on one axis (X,YY,Z).  I intend to use the Gmoccapy interface and the Mesa 7i76E board hardware part.  I've never built a Gantry machine and I would like to understand the correct way to do it, I have a question.  The hardware part do I use pulse and direction signals in parallel together on the same axis (in my case Y axis), or on different X(0), Y(1), Z(2) and Y2(3) axes?  And the software part I create a normal machine in three axes then I add another joint, or if I connect the physical part of pulse and direction together (in parallel) the same axis as the Y (1) I don't need it.
Could someone enlighten me.
Tks
Ingo
4 years 3 months ago #246629 by GuiHue
Replied by GuiHue on topic Gantry and Gmoccapy
Hi Ingo,
thanks to the abstraction concept of LinuxCNC, the GUI is independent of the axis configuration. Using 2.8.2 you want to set up each axis as an individual joint, with the Y axis having two joints. Personally, I prefer to call them X (Joint0), Y1 (Joint1), Y2 (Joint2), Z (Joint3). The reason you want this is to benefit from gantry squaring using home offsets.
I run a gmoccapy 2.8.2 setup with a 7i76e and YXXZ(A) config. The config is reasonably documented and available here:
github.com/GuiHue/kondor/
  • Ingo
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #246685 by Ingo
Replied by Ingo on topic Gantry and Gmoccapy
thank you very much, i will study
  • Ingo
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #248034 by Ingo
Hello,
I managed to create XYYZ machine, I have a doubt in the home of the YY axis (tandem).  Do I need to have the physical reference switch for each axis, or one for both axes?
4 years 3 months ago #248117 by rodw
Replied by rodw on topic Gantry and Gmoccapy
each joint needs its own home switch and it must stay triggered to end of travel.
Time to create page: 0.095 seconds
