No module named vismach!!!
- EdisonBin
- Thank you received: 4
06 Jul 2022 02:19 #246690
by EdisonBin
No module named vismach!!! was created by EdisonBin
Hello, guys!
I have a problem without a clue。
I have a project that works well in linuxcnc 2.8.2.
Today, I updated linuxcnc to 2.9, and the update went very smoothly
When I copied the project 2.9 and ran it, the terminal reported an error!
Prompt I can't find "vismach"
How can I solve it??
This project is used after I use the example of linuxcnc 2.8.2. So I don't know what caused the error it prompted。
I put the picture below, thank you
- EdisonBin
06 Jul 2022 03:16 - 06 Jul 2022 03:18 #246692
by EdisonBin
Replied by EdisonBin on topic No module named vismach!!!
When I annotate the line above with errors:
# from vismach import*
Run linuxcnc again. This time, the error is the following line of code:
import hal
I'm very confused. Is there a big difference between linuxcnc2.9 and linuxcnc2.8.2?
Because in linuxcnc 2.8.2, almost all "Hal" files I create need "import Hal" at the beginning
ls there anything missing from my installation of 2.9? But the SIM of 2.9 works normally
Thank you!
import hal
Thank you!
Last edit: 06 Jul 2022 03:18 by EdisonBin.
- Thank you received: 2176
06 Jul 2022 05:46 #246698
Replied by Aciera on topic No module named vismach!!!
version 2.9 is python3 only.
I can't see what you have in your "mtrobot_gui" file but check that the shebang at the beginning is
#!/usr/bin/python3
or maybe:
#!/usr/bin/env python3
#!/usr/bin/python3
or maybe:
The following user(s) said Thank You: EdisonBin
- EdisonBin
06 Jul 2022 06:18 #246701
by EdisonBin
Thank you very much! I have no idea that this problem is the cause
I was:
#!/usr/bin/python2
Change to:
#!/usr/bin/python3
It's solved!
Thank! Now I can continue to solve the problem of switching kinematics
I was:
#!/usr/bin/python2
Change to:
#!/usr/bin/python3
It's solved!
