Interface signals for .hal files and PLC programm
06 Jul 2022 14:58 #246720 by Diel
Hi everyone.
I am new on Linux CNC but I am usual with CNC machines and CNC controlers. I used to work for a machine tool builder implementing Siemens, Fagor, Heidenhain, Fidia and others brands of CNC.
I am finishing my first and second projects but I have a few doubts.
On the other controls that I have used, we have a list of interface signals between the PLC and the CNC. Once we have the hal files on the Linux CNC, I think we can create the link to the linux cnc signals to be used on the PLC if needed. But still I have nbot found a list of the Linux interface signals that can be used on the hal files to be linked to the PLC.
In this particular case, I need to switch on a relay whenever the spindle will run with M3 or M4.
I also need to implement the oriented stopĀ  on the spindle for an automatic tool changer (what I am studying how to do it on the Linux CNC).
I will be very thankfull for any tips, documentation or comments on those topics.
Thank you all in advance.
07 Jul 2022 00:48 #246766 by cmorley
The following user(s) said Thank You: Diel
07 Jul 2022 14:16 #246804 by Diel
Hi there.
I figure out how to implement the M3 and M4 command to the PLC. I am working on the M19 and the tool changer.
Would anyone have any examples on automatic tool changers? I do have a fixed position 21 positions disc as a magazine.
Z movements will engage the tool on the spindle.
Any tips will help.
11 Jul 2022 19:06 #247096 by Diel
Hi there,I checked the link you send. I found it very useful. Thank you.
However, the signal "spindle.N.orient" that I think I have to use seams to do not work.
The N I believe is my spindle number. Once I have just one spindle, I belive N should be 0 or 1.
But now I think I should use 9 once in my CNC.ini PNCCONFIG make the configuration like:
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
Thank you very much. I will try again with 9.
"spindle.N.orient" - (out,bit) Indicates start of spindle orient cycle. Set by M19. Cleared by any of M3,M4,M5. If spindle-orient-fault is not zero during spindle-orient true, the M19 command fails with an error message.
16 Jul 2022 11:28 #247449 by andypugh
The signals available depends on what components are loaded.
You will always have all the pins here:
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
And
linuxcnc.org/docs/stable/html/man/man1/io.1.html
And nearly always:
linuxcnc.org/docs/stable/html/man/man1/halui.1.html
These are from "motion", "io" and "halui" respectively.
For the rest, expand the "Commands and userspace components" and "Realtime components and kernel modules" sections here: linuxcnc.org/docs/stable/html/ It's worth quickly looking through them all (especially the realtime ones) just to get a feel for what is available.
Time to create page: 0.082 seconds
