Running HAL commands from python?
- thadwald
- Thank you received: 10
12 Jul 2022 04:47 #247116
by thadwald
Running HAL commands from python? was created by thadwald
Hi
I am working on a custom UI with gscreen. Is it possible to run arbitrary HAL commands from python?
If so, how? Examples?
Thanks!
Thanks!
- phillc54
- Thank you received: 2100
12 Jul 2022 09:19 #247127
by phillc54
Replied by phillc54 on topic Running HAL commands from python?
There are some examples using the Hal module and hal_glib module here:
linuxcnc.org/docs/2.8/html/hal/halmodule.html
- thadwald
13 Jul 2022 12:43 #247231
by thadwald
Replied by thadwald on topic Running HAL commands from python?
Thanks for the reply.
I looked this over and I don’t think that “creating a user space component” is what I need to do.
I need to somehow start and stop a realtime thread, among other things. Is this possible?
- Thank you received: 4648
16 Jul 2022 19:12 #247493
Replied by andypugh on topic Running HAL commands from python?
import os
os.system("halcmd start")
Not super satisfying, but works.
The following user(s) said Thank You: thadwald
- thadwald
17 Jul 2022 19:28 - 17 Jul 2022 20:06 #247583
by thadwald
Thank you.
Actually, what I think I want is:
os.system("halcmd -kf")
This appears to work but then it doesn't return and my program is stuck. I can't find an "exit" command for halcmd. Does it have one?
Otherwise, is there a way to send a ctrl-c as part of a script?
Edit: my bad; I was under the impression that I need to provide the -f option to interact with the current instance ...
Last edit: 17 Jul 2022 20:06 by thadwald.
17 Jul 2022 20:47 #247593
To get out of the halcmd prompt you normally do use "exit"
But I have no idea where you are if you have done that from inside Python.
- thadwald
17 Jul 2022 21:17 #247595
by thadwald
My mistake was to use the -f option. When I run each line with halcmd, the commands work.
I have another issue now.
When I run the following command:
The command works; it adds the thread. but it causes the hm2 watchdog to time out.
Is there a good way around this issue? Can I temporarily disable the hm2 watchdog?
It is easy enough to reset the watchdog but then I need to re-home the machine. For this specific use case, re-homing isn't a showstopper but it is not preferable.
More generally, what I am trying to accomplish is to create a cmm using sampler. It is important for this application to set the sample frequency to an arbitrary value, so I want to run it in a separate thread.
Should I abandon this approach and just parse and cull the sampler output instead?
halcmd loadrt threads name1=cmm-thread period1=10000000000The command works; it adds the thread. but it causes the hm2 watchdog to time out.
17 Jul 2022 22:58 #247603
Do you really want a 1 second thread? That seems to be more than the usual number of zeros.
- thadwald
17 Jul 2022 23:07 #247604
by thadwald
No, I fat-fingered a few too many in there. The actual period is calculated from scan speed and point interval specified by the user.
21 Jul 2022 09:13 - 21 Jul 2022 09:14 #247921
There is, I think, some sort of limitation that threads have to be added in order, though I am not sure i it is slow to fast or vice-versa.
I would try experimenting in a bare halcmd prompt and see what happens.
ie, see what you are allowed to do without the rest o LinuxCNC interfering.
halcmd -kf
loadrt threads name1=thread1 period1=200000
unload threads
loadrt threads name2=thread2 period=1000000
exitie, see what you are allowed to do without the rest o LinuxCNC interfering.
Last edit: 21 Jul 2022 09:14 by andypugh. Reason: The manpage mentions unloading and loading again to add a thread.
Time to create page: 0.108 seconds
