Rotary Program Feed rate question
- Thank you received: 4648
25 Jul 2022 13:22 #248255
Replied by andypugh on topic Rotary Program Feed rate question
It will tend to depend on what proportion of the time the A axis speed is the limiting factor.
It would be interesting to convert the same G-code to G93 and see what happens.
- rajsekhar
- Thank you received: 12
25 Jul 2022 15:31 #248261
by rajsekhar
Replied by rajsekhar on topic Rotary Program Feed rate question
I will do that and update the result.
Actually using the same G code with G93 causes error in some cases as F number is not generated in a few lines. However, I will manually put some F number and run the same Gcode. I hope the manual editing in a few lines only will not introduce much error.
- rajsekhar
27 Jul 2022 17:03 #248433
by rajsekhar
Today I tested the program with G93 Inverse feed (G94 & G93 gode files attached).
Timing:
Timing:
- G94: 1 hr 5 min.
- G93: 1 hr 5 min.
Time to create page: 0.079 seconds
