Move Trajectory planner from real time to non-real time
- troy
- Thank you received: 4
06 Feb 2023 06:10 - 09 Feb 2026 02:28 #263795
by troy
Replied by troy on topic Move Trajectory planner from real time to non-real time
none
Last edit: 09 Feb 2026 02:28 by troy.
- troy
06 Feb 2023 06:23 - 09 Feb 2026 02:28 #263798
by troy
none
- troy
06 Feb 2023 06:30 - 09 Feb 2026 02:29 #263800
by troy
none
Last edit: 09 Feb 2026 02:29 by troy.
The following user(s) said Thank You: Lcvette
- Lcvette
- Thank you received: 784
07 Feb 2023 16:50 #263957
by Lcvette
Replied by Lcvette on topic Move Trajectory planner from real time to non-real time
This looks very promising!! subscribed!
- troy
09 Feb 2023 01:38 - 09 Feb 2026 02:29 #264086
by troy
none
- Lcvette
09 Feb 2023 20:50 #264165
by Lcvette
it would seem the best way for that to happen would be to have a jumping off point. it appears you have created that point with your work as seen by the results, it would likely be easiest to put it out for broader testing and contribution and once it seems to have been proven in a broader environment and any kinks ironed out, set it up as a pull request to Linuxcnc. I am certain that many of the people who use linuxcnc in a production environment would be thrilled to see a way to remove the jerk situation from their machines. I for one can 100% say I would.
Chris
Chris
- Becksvill
- Thank you received: 115
10 Feb 2023 23:33 #264261
by Becksvill
Replied by Becksvill on topic Move Trajectory planner from real time to non-real time
and i am very keen also for any new trajectory control stuff!
i run big linuxcnc machines all day and currently they run a lot more roughly than with the original heidenhain controls and shake the machine way more
i would also love to do some testing for you if that would get this forward. my coding skills are currently only basic but i do a lot of linuxcnc retrofits in new zealand
Andrew
Andrew
- IonCarver
- Thank you received: 3
26 Mar 2023 21:38 #267560
by IonCarver
Replied by IonCarver on topic Move Trajectory planner from real time to non-real time
Hi there,
Is any news on this topic or some kind of github code to try it?
Best
Best
The following user(s) said Thank You: tiagounderground
- viesturs.lacis
10 Feb 2025 13:22 #321158
by viesturs.lacis
We need you to share your code so that it can be improved and hopefully merged back in LinuxCNC. Is there any chance that you could publish it in any way?
Replied by viesturs.lacis on topic Move Trajectory planner from real time to non-real time
Hello troy!
I have verified that the solution is feasible.
This can be a development direction of linuxcnc in the future, I am very willing to participate in it, If the development thread starts.
Time to create page: 0.177 seconds
