G Code editor
20 Jul 2022 15:01 #247853 by rajsekhar
G Code editor was created by rajsekhar
Friends, I am looking for some reliable G-code editor softawre/ tools.
Manual editing is horrible job because of the line numbers.
What are the options??
  • Moderator
  • Moderator
20 Jul 2022 17:32 #247862 by tommylight
Replied by tommylight on topic G Code editor
For what?
What exactly are you trying to do?
Editing a gcode for 3D printing is tedious, for milling also, but for plasma it is doable.
Editing can be done in any text editor.
Line numbers are ignored, usually.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
20 Jul 2022 17:56 #247864 by Todd Zuercher
Replied by Todd Zuercher on topic G Code editor
A really nice editor (with plotting capabilities) is Ncplot. it has the capability to add, remove, or renumber N-line numbers. As well as a number of other handy g-code manipulating features. But the nicest part of it is that it can plot out subprograms, macro programs, and parametric code in Fanuc style g-code. Those features almost make it almost indispensable for complex g-code editing of those kinds of programs.
That said, Linuxcnc really doesn't use N-numbers for anything and it doesn't even care if the N-numbers are out of order, so if they get in your way, just leave them out. I also use regular text editors such as Pluma, and Gedit, also simple IDEs such as Geany or Notepad++ can also be very nice G-code editors.
20 Jul 2022 21:07 #247878 by JT
Replied by JT on topic G Code editor
Line numbers serve no purpose in G code and are annoying.
Drop line numbers and use any text editor, Geany, Pluma etc.
JT
22 Jul 2022 03:40 #248002 by rajsekhar
Replied by rajsekhar on topic G Code editor
My purpose for editing is as follows:
I am doing some engraving job on round workpiece, practically silver glass.
My machine is XZA configuration.
Now if I want a endless engraving on a glass then I need to manually edit gcode to lift the Z axis for the X movements at A=360,540 etc. Although I try to avoid lines along X in drawing at both ends, but pocketing operation inherently cause X lines while engraving the boundary and contouring again creates the same.
It is a tedious job, but I need to satisfy the customers.
Any better solution if anyone may suggest please?
22 Jul 2022 11:40 #248022 by andypugh
Replied by andypugh on topic G Code editor
It is possible that WRAPPED_ROTARY might help:
linuxcnc.org/docs/stable/html/config/ini...lt_letter_gt_section
25 Jul 2022 15:43 #248265 by rajsekhar
Does LinuxCNC accept Gcodes with line numbers?? I have not tested it actually.
25 Jul 2022 15:46 #248266 by rajsekhar
Actually I wanted to say without line numbers??
sorry for typing error.
  • Moderator
  • Moderator
25 Jul 2022 17:24 #248271 by tommylight
Yes.
26 Jul 2022 10:29 #248311 by andypugh
It doesn't matter what the question was, as the answer is "yes" in both cases.
LinuxCNC completely ignores line numbers.
Time to create page: 0.101 seconds
