- LinuxCNC
- General LinuxCNC Questions
- Dubug file information: insmod:ERROR:could not load module /usr/realtime-4.19.19
- sf9090
21 Jul 2022 07:13 #247915
by sf9090
Dubug file information: insmod:ERROR:could not load module /usr/realtime-4.19.19 was created by sf9090
Hello, yesterday I installed EtherCAT on my Debian system with linuxcnc. The 'EtherCAT slaves' successfully returned data, but when I turned back to open linuxcnc, I reported an error:
```clike
insmod:ERROR:could not load module /usr/realtime-4.19.195-rtai-amd64/modules/rtai_hal.ko:No such file or directory
2654
Stopping realtime threads
Unloading hal components
Note :Using POSIX non-realtime
rmmod:ERROR;Module rtai_sched is not currently loaded
rmmod:ERROR :Module rtai_hal is not currently loaded
```clike
2654
- Thank you received: 4648
21 Jul 2022 19:23 #247980
Replied by andypugh on topic Dubug file information: insmod:ERROR:could not load module /usr/realtime-4.19.19
Which kernel are you running?
Did you compile from source?
What do you have in /usr/realtime........
- Thank you received: 7462
25 Nov 2022 11:25 #257612
Replied by tommylight on topic Dubug file information: insmod:ERROR:could not load module /usr/realtime-4.19.19
@sf9090,
Do not report members that did nothing wrong.
Pretty sure ethercat does not work with RTAI kernels, it requires RT-preempt kernel to work.
- LinuxCNC
Time to create page: 0.071 seconds
