switchkins - using own kinematics module as kinstype=2
  • mittim
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #248134 by mittim
Hey there,
i want to use switchkins with my own kinematics module.
Currently I am using xyzac-trt-kins and it is working fine. In addition i want to use switchkins with my own kinematics module named "userkfuncs.c".
1. What do I need to change in the "userkfuncs.c" for switchkins to use it as kinsytpe=2?
2. In which directory do I put the "userkfuncs.c" file?
3. How do I compile the "userkfuncs.c" file?
Any help is appreciated, thanks!
4 years 3 months ago #248146 by dgarrett
Ref: linuxcnc.org/docs/devel/html/motion/switchkins.html
> 6. User kinematics provisions
> Custom kinematics can be coded and tested on
> Run-In-Place (RIP) builds. A template file
> src/emc/kinematics/userkfuncs.c is provided in the
> distribution. This file can be copied/renamed to
> a user directory and edited to supply custom
> kinematics with kinstype==2.
> The user custom kinematics file can be compiled
> from out-of-tree source locations for rt-preempt
> implementations or by replacing the in-tree
> template file (src/emc/kinematics/userkfuncs.c)
> for rtai systems.
> Preempt-rt make example:
> $ userkfuncs=/home/myname/kins/mykins.c make && sudo make setuid
Example:
$ mkdir /tmp/test ;# anywhere you want
$ cd your_LINUXCNC_GIT_TOP_DIRECORY
$ cd src
$ cp emc/kinematics/userkfuncs.c /tmp/test/try.c
$ # edit /tmp/test/try.c
$ # show your edits:
$ diff emc/kinematics/userkfuncs.c /tmp/test/try.c
55a56
> rtapi_print("*************HELLO %s %d\n",__FILE__,__LINE__);
$ # build:
$ userkfuncs=/tmp/test/try.c make && sudo make setuid
Reading 205/205 dependency files
Done reading dependencies
!!!USERKFUNCS=/tmp/test/try.o
Linking ../rtlib/xyzac-trt-kins.so
$ # test:
$ halrun
halcmd: loadrt xyzac-trt-kins
Note: Using POSIX realtime
userkKinematicsSetup:
/tmp/test/try.c <xyzac> max_joints=16 allow_duplicates=1
*************HELLO /tmp/test/try.c 56
  • mittim
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago - 4 years 2 months ago #250112 by mittim
what I tried: sudo userkfuncs=/home/tim/linuxcnc-dev/custom_kinematics/userkfuncs.c make && sudo make setuid
When I want to comile the file I am getting the following error message:
"Es wurden keine Ziele angegeben und keine make Steuerdatei gefunden"
translation: "no directory assigned and no make file found"
What am I doing wrong?
Last edit: 4 years 2 months ago by mittim.
  • Moderator
  • Moderator
4 years 2 months ago #250218 by tommylight
This quote was used to start a new topic, so it was deleted after some consultation.
Back on topic:
The error :"no directory assigned and no make file found" is usually due to starting a compile in the wrong directory, so going back one level and running the compile again usually works.
  • mittim
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago #250259 by mittim
I edited the "userkfuncs.c" file to my needs and build linuxcnc again. Everything compiles and builds fine without error messages.
I want to use userkfuncs as kinstype==2. But when switching, my kinematics module is not working. Any ideas?
4 years 2 months ago #250277 by Aciera
So when you switch to kinstype==2 do you get any information in the terminal about what is happening?
Have you verified in halshow that the kinstype pin has actually changed it's value to "2"?
  • mittim
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago - 4 years 2 months ago #250499 by mittim
Thanks for your help Aciera,
I managed to set up userkfuncs.c as my switchkinstype 2.
But there is still one problem I am facing. I want to adjust the xyzac-trt-kins (switchkins type 0) to my needs (reducing the TCP to my geomtrical machine rrors only).
So, to test, whether I am on the right path, I used the trtfuncs.c kinematics in my userkfuncs.c module. The problem is, that the macine is still in identity kinematics when changing to switchkins-type 2.
To make my problem clerar:
1. In which module is the TCP kinematics beeing calculated?
2. Why does switchkinstype 2 not use TCP, when I am using trtfuncs.c code?
3. Is there an example, where someone has written his own kinematics module or adjusted one to his needs?
I attached the userkfuncs.c file, which I am trying to use.
4 years 2 months ago #250517 by Aciera
1. I presume the calculation is in "trtfuncs.c"
2. I have a feeling that your custom userfuncs.c might not get called that is why I suggested to verify that the hal pin "kinstype_is_2" is indeed "true".
3. I don't know of any examples using the "userfuncs.c" template. But I have created custom kinematics using the "userkins.comp" template (see "configs/sim/axis/vismach/millturn" the corresponding "millturn.comp" is here github.com/LinuxCNC/linuxcnc/blob/master...onents/millturn.comp
The following user(s) said Thank You: mittim
  • mittim
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago #250518 by mittim
I have checked the hal pin and it is kinstype_is_2 that becomes true with my command: setp motion.switchkins-type 2.
Is it possible to change the trtfuncs.c file and build linuxcnc again? (I know that may cause problems in the future)
4 years 2 months ago #250519 by Aciera
Yes that should work.
Time to create page: 0.090 seconds
