switchkins - using own kinematics module as kinstype=2
4 years 2 months ago #250574 by Aciera
Only explanation I can come up with is that you are not setting the environment to the correct installation folder you used to build linuxcnc to.
The other way would be to use the above mentioned "userkins.comp" template as that doesn't require a rebuild but can be installed using "halcompile".
4 years 2 months ago #250575 by mittim
How do I set the environment to the correct folder? Can't really follow you at that point.
4 years 2 months ago - 4 years 2 months ago #250576 by Aciera
I presume you have installed linuxcnc something like this, ie a rip-install into a folder called "linuxcnc-dev" or using another folder name:
> git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
> cd linuxcnc-dev/src
> ./autogen.sh
> ./configure --with-realtime=uspace
> sudo make setuid
Then after that you need to set the environment like this:
> source ../scripts/rip-environment
Then you can start linuxcnc from the rip-installation
> linuxcnc
Last edit: 4 years 2 months ago by Aciera.
The following user(s) said Thank You: mittim
4 years 2 months ago #250580 by mittim
Thank you so much for your help. I had to run it out of the terminal.
Now, I have compensation for xyzac and xyzbc machines with an offset of the Rotary Axis without using TCP.
Time to create page: 0.083 seconds
