Machine moves by itself
- Ingo
28 Jul 2022 21:34 #248592
by Ingo
Machine moves by itself was created by Ingo
Hello guys,
lt's the first time I make a machine with a parallel port. The machine is all ready and working, but the machine is stopped, the spindle is off, it moves by itself slowly in the direction of X+, Y+ and Z-. Has anyone ever experienced this? Before she was half crazy with the spindle turned on, I isolated the power cable from the spindle and that problem solved….
- smc.collins
- Thank you received: 139
29 Jul 2022 02:59 #248600
by smc.collins
Replied by smc.collins on topic Machine moves by itself
sounds like floating ground voltage between servi drive inputs a pc output
- Thank you received: 7490
29 Jul 2022 17:55 #248639
Replied by tommylight on topic Machine moves by itself
Servo motors or stepper motors?
In case of servo, DC or AC servo?
- Ingo
01 Aug 2022 00:57 #248762
by Ingo
Replied by Ingo on topic Machine moves by itself
I am using 220v DC servo motors
- Ingo
01 Aug 2022 01:00 #248763
by Ingo
Hello Collins,
I made an improvement in the grounding of the control board and it seems that it solved, I did about 4 hours of tests and it didn't present this problem anymore.
At first solved thanks a lot for the help
Ingo
Ingo
- Ingo
17 Aug 2022 02:20 #249927
by Ingo
Hello friends,
I've been in battle since Thursday, because the problem is back…. I did the grounding and at first for a moment it resolved but now it came back worse with more force. My question is related to transmission speed ( Feed x scale ), for example the encoder resolution is at 4000ppv, the machine speed is at 5000mm/min and the scale is at 400, is this related?
17 Aug 2022 09:43 #249939
Do they move when LinuxCNC is not running?
Are you using a Mesa 7i77, meaning the drives are in velocity mode?
Do they move when LinuxCNC is on and enabled?
- Thank you received: 1480
17 Aug 2022 13:12 #249950
Replied by Todd Zuercher on topic Machine moves by itself
What hardware are you using to read the encoders, and interface with the servo drives?
- Ingo
17 Aug 2022 15:58 #249953
by Ingo
When LinuxCNC is in normal automatic mode, but when it is stopped with the servo-on active, it starts to move by itself. I'm not using 7i77, a generic parport.
- smc.collins
17 Aug 2022 16:11 - 17 Aug 2022 16:15 #249955
by smc.collins
my machine will do the same thing, do you have the drive enable routed through the 7i77 ? if not, do that, almost all velocity mode drives tend to creep due to voltage fluctuating and ground voltage variances.
Mesa electronics does sell a galvanic isolation adapter for the db25 that should in theory solved this issue.
i have electrokraft 400 brushed motor drives.
this is all very common, just run the drive enable control through the 7i77 on ENA + - on the tb connectors
Last edit: 17 Aug 2022 16:15 by smc.collins.
