Analog Input in realtime
  • rajsekhar
  • Topic Author
  • Elite Member
  • Elite Member
4 years 2 months ago #249126 by rajsekhar
Analog Input in realtime was created by rajsekhar
Dear Friends..
I want to know the ways to have a sensor analog output to be read into linuxcnc in realtime.
The application I am looking for is adaptive feed control in lathe/mill via power (current sensor) measurement.
Earlier, I have sucessfully taken integer input from arduino (usb connected) into hal (via python). But that I think was not in realtime.
How realtime float input is possible??
4 years 2 months ago #249131 by Henk
Replied by Henk on topic Analog Input in realtime
Best sollution is probably one of Mesa's THCAD cards. It is basically an A/D converter that outputs a signal that can be counted with one of the encoder inputs
There is a 10v and a 300v version
4 years 2 months ago #249132 by PCW
Replied by PCW on topic Analog Input in realtime
A 7I87 is another possibility if you need multiple channels
Also there is a crude (8bit) 4 channel analog input capability on many Mesa daughtercards
(7I73,7I76,7I77,7I84)
4 years 2 months ago #249136 by tommylight
Replied by tommylight on topic Analog Input in realtime
Or write a driver for using analog Line Inputs on the motherboard, 2 inputs at high resolution, but also high sensitivity (usually 1VPP).
4 years 2 months ago #249165 by andypugh
Replied by andypugh on topic Analog Input in realtime
No eBay APP ID and/or Cert ID defined in Kunena configurationOr: Use a PWM output into a filter, and a (physical) comparator to feed back if your pwm is higher or lower than the measured voltage, then a PID loop in HAL trying to achieve a value of 0.5 in the feedback will track the external voltage.
Probably.
I have never actually tried this, but its basically a crude "tracking ADC" implemented in HAL. It will cost you two IO pins, though.
You could also bitbang an I2C ADC: or similar, but that might not be fast enough (it will take 32mS to bitbang a 16 bit value out of it)
If you are using a Mesa card, then there is an SPI module in the firmware, and then an external ADC could be sampled at 1kHz.
Time to create page: 0.056 seconds
