Scale size of Axis interface bottons
  • Routerworks
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago #249140 by Routerworks
Scale size of Axis interface bottons was created by Routerworks
I have been very comfortable with using the setup I get with the cnc wizard. However it would be helpful to me if there was a way of  increasing the screen size of some of the control buttons such as; xyz axis, homeall, touch off ets.  If there is a straight forward way to do this I would like to learn it.  Don't want to create major changes as I am quite satisfied the format functions.
Just upgraded to Wheezy V 2.8
4 years 2 months ago #249171 by andypugh
Replied by andypugh on topic Scale size of Axis interface bottons
I am going to assume that you are not the sort of monster who would consider running an LCD display at anything other than native resolution?
In which case I would guess that button sizes are set somewhere in axis.tcl, but I am too unfamilar with Tcl to be able to find where.
You might look at Gaxis, which is superficially similar to Axis but defined by a more editable GUI system.
linuxcnc.org/docs/html/gui/gscreen.html
  • Routerworks
  • Topic Author
  • Premium Member
  • Premium Member
4 years 2 months ago #249222 by Routerworks
Replied by Routerworks on topic Scale size of Axis interface bottons
Correct not that kind of monster.
I'll check our your link.
Thanks a lot.
4 years 2 months ago - 4 years 2 months ago #249327 by HansU
Replied by HansU on topic Scale size of Axis interface bottons
In case you want to optimize it for a touch screen, I would recommend to use linuxcnc.org/docs/html/gui/gmoccapy.html
Or you can get some inspiration from this thread: forum.linuxcnc.org/21-axis/40659-axis-2-...ersion-of-old-friend
Last edit: 4 years 2 months ago by HansU.
4 years 2 months ago #249348 by cakeslob
Replied by cakeslob on topic Scale size of Axis interface bottons
Hey, resizing the buttons is not very complicated. Have a read through these axis documents, they describe how it can be done. the example provided is for the toolbar buttons, but it can be done with the other buttons as well. The hardest part is at first when you are trying to figure out what button is what.
linuxcnc.org/docs/devel/html/gui/axis.html#_user_command_file
linuxcnc.org/docs/devel/html/gui/axis.ht..._the_toolbar_buttons
www.forum.linuxcnc.org/media/kunena/atta...command_dark2INFO.py
You can find all the button names within this file, but I dont have it all labeled as to which ones are buttons. I will have to check when I am home from vacation, and I can post a clearer explanation, if you are still having issues.
Time to create page: 0.087 seconds
