Raspberry Pi 4 image does not auto-update
4 years 2 months ago - 4 years 2 months ago #249279 by prochj51
I downloaded the official RPi4 image from linuxcnc.org .
Documentation says it should auto-update to LinuxCNC 2.8.2, but it throws error
Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable' instead
Are there any stable images for LinuxCNC 2.8.2?
Thank you
George
Last edit: 4 years 2 months ago by prochj51. Reason: Wrong formatting
4 years 2 months ago #249280 by elovalvo
4 years 2 months ago #249281 by prochj51
Thank you,
and how do I get the RPi4 image with realtime kernel?
4 years 2 months ago - 4 years 2 months ago #249282 by elovalvo
-Open a terminal and type:
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
-reboot
or follow the instructions here
github.com/kdoren/linux/releases
Last edit: 4 years 2 months ago by elovalvo.
4 years 2 months ago #249289 by prochj51
I have problems updating the buster image overall.
Is there any RPi image with LinuxCNC with bullseye?
4 years 2 months ago #249321 by elovalvo
As far as i know, LinuxCNC version 2.8.2 is not compatible with Bullseye.
If you want to try a image with 64-bit version 2.9.0pre, you can see at this link:
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#238020
Time to create page: 0.359 seconds
