Vantec 2-Port Parallel PCIe Card (UGT-PCE20PL)
  • Bari
  • Bari's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Aug 2022 23:33 #250173 by Bari
UGT-PCE20PL
vantecusa.com/products_detail.php?p_id=1...pt_name=Add-on+Cards
www.amazon.com/gp/product/B00EA0WKDG/ref...b_asin_title_o00_s00
Works well with software stepping with LCNC. Both ports work. Comes with standard and low profile brackets. Did not test for EPP compatibility with Mesa or Pico.
The following user(s) said Thank You: Todd Zuercher, tommylight, Scrappy_000, JT
  • Bari
  • Platinum Member
  • Platinum Member
22 Aug 2022 00:55 #250181 by Bari
Pic of UGT-PCE20PL
  • Bari
  • Platinum Member
  • Platinum Member
23 Aug 2022 05:04 #250239 by Bari
Both parallel ports also show up using Stepconf Wizard.
The following user(s) said Thank You: Todd Zuercher, tommylight, JT
Time to create page: 0.156 seconds
