I can't seem to get truetype-tracer installed
  • skrap58
  • skrap58's Avatar Topic Author
  • Senior Member
  • Senior Member
24 Aug 2022 20:36 #250349 by skrap58
I am having a tough time getting truetype-tracer installed on linux mint 19.1 mate.  I have everything else up and running with linuxcnc but I cannot run any of my text  xml files for vcarving text in nativecam.  I suspect that ngcgui ttf will not work either without truetype tracer and ttf freefont installed.  I have everything installed on a 64 bit Thinkcenter m series.  Using a parallel port for running linuxcnc.  Linuxcnc 2.8.  I had everything working fine on an old i386 Dell on linux mint but lost the truetype-tracer capability when I upgraded.
If anyone can point me in the right directions it would be greatly appreciated.
Skrap58
  • Moderator
  • Moderator
24 Aug 2022 21:52 #250353 by tommylight
Replied by tommylight on topic I can't seem to get truetype-tracer installed
This is the third topic with the same subject started by you, although one of those is from 2017 and two are in last week.
I just wasted 15 minutes looking for what is going on with truetype tracer and it seems it is a LinuxCNC thing, not Linux, so i found it here:
linuxcnc.org/dists/stretch/base/binary-a...acer_4.1-4_amd64.deb
Download and install with gdebi or by double clicking on it.
I am deleting the other new topic.
Here is the old one:
forum.linuxcnc.org/nativecam/33230-truet...in-nativecam?start=0
Time to create page: 0.076 seconds
