Malin board with Linuxcnc
- GlenB
25 Aug 2022 01:59 #250371
by GlenB
Malin board with Linuxcnc was created by GlenB
Hello,
New to this forum.
I saw several YouTube videos on the software, and wondered if I could interface it to a Marlin boaerd running gcode?
What I have done is take an BTT SKR 1.4 turbo board and remove the stepper driver modules. I designed a board that converts the
raw stepper outputs for all three axis to open collector, and run them to the DM556 external driver modules. It works great.
I just wondered if one of the LinuxCNC program options might be to communicate with another Marlin control board?
You know the one about "the only stupid question is the question never asked"
GlenB
Moultrie, GA
New to this forum.
GlenB
Moultrie, GA
- Thank you received: 2181
25 Aug 2022 05:30 #250374
Replied by cmorley on topic Malin board with Linuxcnc
I'm not sure what a marlin board is.
Linuxcnc is a motion controller, that basically output velocity signals.
if the marlin board expects step/direction or analog signals then yes.
If it expects Gcode then no.
Also communication over USB is out with linuxcnc.
There are more details, but that is the quick answer.
- Thank you received: 7488
25 Aug 2022 09:58 #250391
Replied by tommylight on topic Malin board with Linuxcnc
Marlin is the software cnc controller used on 3D printers and boards like Arduino Mega.
So no, you can not use LinuxCNC to control a marlin board, but you can flash Remora that is made for use of such boards with LinuxCNC.
Here is everything regarding remora on this website/forum:
www.google.com/search?q=remora+site%3Ali...org&aqs=heirloom-srp..
- GlenB
25 Aug 2022 10:18 #250392
by GlenB
Replied by GlenB on topic Malin board with Linuxcnc
Thanks for the reply. Yes, the Marlin control board controls the stepper motors, limit switches, etc.
One would use Gcode via the USB. There is a RPI interface for remote control using OctoPrint, whereby one could completely control the 3D printer remotely (even using a remote camera).
I will investigate the Remora stuff!
GlenB
GlenB
25 Aug 2022 10:23 #250393
Octoprint can be installed on normal PC and android phones, not just RPI. On phones it also uses built in camera for timelapse and monitoring.
Time to create page: 0.101 seconds
