Spindle Orient - No motion
25 Aug 2022 03:00 #250373 by jroddds
Spindle Orient - No motion was created by jroddds
I feel like I am missing something right under my nose.  Spindle runs as expected in velocity mode.  But I'm trying to get spindle orient to work and I am having no luck.  MDI (after homing) produces no motion on M19 command.  I have trien M19 Rx.x and M19 Rx.x Qx Px but nothing happens.
Had configuration shows SpinEna and SpinOut are producing outputs.  All output signals seem to be working in both Vel mode and Orient Mode.  Mus and Or2 signals working.  I just don't know what I'm missing.  Maybe someone can point out my error.  Appreciate the help.
Some of the Hal and Ini files have been compiled from other LinuxCNC users
27 Aug 2022 04:24 #250559 by jroddds
Replied by jroddds on topic Spindle Orient - No motion
Maybe I should also mention my VFD is a Hitachii Wj200 vector drive. The spindle is a vector duty motor 20:1. I did wonder if the orient is not putting out a strong enough signal to the drive for it to register a signal. But then again, the SpinOut signal is 800 and still has no motion. In velocity mode the spindle will turn at less than 200 rpm.
28 Aug 2022 03:49 #250601 by spumco
Replied by spumco on topic Spindle Orient - No motion
If the Hitachi is responding to a 200rpm velocity command then the orient output should also work - i.e. it's not a 'not strong enough signal'
I'll take a look at your hal and see if I can find something.  I'd post mine but it's a mess right now and would likely confuse you.
28 Aug 2022 04:26 #250603 by spumco
First
Move your addf to a line after the motion-controller line.  I remember reading somewhere - I think from PCW - that the sequence you addf components is critical.  Don't know if this is the root of all your woes, but mine is like this and it works.
addf hm2_7i76e.0.read              servo-thread
addf motion-command-handler   servo-thread
addf motion-controller               servo-thread
[i]addf orient                               servo-thread[/i]
Next,
sets spindle-at-speed true
Why is this in there?  Your near component should be working to get the spindle-at-speed to trigger.  I don't know if this would bugger up the orient output but unless you've got a good reason I'd comment this out for testing.
Optional:
Edit your HAL file so the [TUNE] values are in the hal file and not in the INI file.  Like this:
setp   orient-pid.Pgain          6000   #[TUNE]P
setp   orient-pid.Igain            300    #[TUNE]I
etc...
Reason for this is that you can edit hal pin values on the fly in halshow while tuning the PID and everything else.  If they're set to follow the INI file values, you can't edit them in halshow.  Once you've got everything tuned up you can un-comment and adjust the 'final' values in the INI file.
Try those two things and see what happens.  You know how to open halshow and watch what's going on while you're testing?
29 Aug 2022 19:56 #250726 by jroddds
Thanks. I will try these fixes when I get home and report back.
30 Aug 2022 04:15 #250753 by jroddds
I tried those fixes, but no luck so far. I'll keep at it. Let me know if anything else comes to mind. Thanks.
30 Aug 2022 17:44 #250792 by jroddds
Aha, the problem was user error. I forgot when I set up my VFD, I was using separate outputs in the hal file for FWD and REV instead of enable/DIR. So the enable signal was working, but it wasn't going to the VFD. Now the orient kicks the VFD on, but it just starts for a half a second and quits. The spindle just coasts to a stop. So now to figure out that issue.
06 Sep 2022 21:43 #251358 by andypugh
Replied by andypugh on topic Spindle Orient - No motion
That sounds like your HAL is setting "oriented" too easily, ie as soon as the spindle is at the right angle, even of it is rotating quickly.
07 Sep 2022 01:11 #251374 by spumco
Once you get that figured out you may find that orienting the spindle with a VFD isn't great without a brake or alignment pin.  VFD'd aren't servos - although that WJ200 has some nice features - and they can't hold a position very well without dithering.  I got pretty close with my GS3 VFD, but wound up having to make an air-actuated alignment dog on the top of my spindle to hold steady it for the ATC drive dogs.
Have you tried homing the spindle using the built-in feature(s) in the VFD?  I have a WJ200 on another piece of equipment but I've never tried using the 'simple positioning' mode described in the manual.  You might play with that a bit if LCNC's orient function gives you fits.
It probably wouldn't be too hard to connect some of the WJ200's digital I/O to LCNC and let the VFD do the homing and report all-good to LCNC.
Time to create page: 0.203 seconds
