Hello all,
I have a linux pc running Command CNC which I had used for some time for my plasma table. Recently I adapted a spindle to the table and long story short, I have a subroutine that was graciously provided to me by Command CNC for my specific semi automatic tool changer setup which worked perfectly, other than the X direction after tool setter touch off. I figured that I could change the X move in the subroutine from + to - myself which I did in something called Fastedit which I grabbed online. I saved it and replaced the mtoolchange.ngc in the subroutine folder on the machine linux pc and tried to open the same cut file as I had tried previously. The file doesn't load, no G-Code on screen and the screen locks up with no ability to click any of the radio buttons I have to do a hard shutdown in order to move on. If I go back to the original subroutine file that was sent to me, it works fine other than the aforementioned X travel direction.
I have attached the subroutine with the change from + to - for the X axis that I made on line 41 and 46. I would appreciate it if someone could take a look and let me know if you see an obvious error and maybe moreover if I need special G-Code editing software.
Thanks in advance,.
Steve
