Problem when I setup the backlash option
- Nest
- Thank you received: 10
04 Sep 2022 12:15 - 06 Sep 2022 21:41 #251165
by Nest
Problem when I setup the backlash option was created by Nest
My electronic is a MESA 7i96
My machine is a routerCNC 3 axis
hi, good day i have a problem with the backlash option, when i setup this option, when the machine is work suddenly in short moving the axis bounces, this happen in the all axis with the option activated, sometimes on the x-axis and sometimes on the y-axis
Someone can help me?
Thanks you so much
Thanks you so much
Last edit: 06 Sep 2022 21:41 by Nest.
- Thank you received: 7462
04 Sep 2022 12:44 #251166
Replied by tommylight on topic Problem when I setup the backlash option
- Nest
06 Sep 2022 20:31 - 06 Sep 2022 20:33 #251348
by Nest
Replied by Nest on topic Problem when I setup the backlash option
Hi, i fix the problem... i had to correct the value of STEPGEN_MAXACCEL and now it works fine
INI Configuration
INI Configuration
Last edit: 06 Sep 2022 20:33 by Nest.
Time to create page: 0.197 seconds
