Join following error in sim mode - SOLVED
- macsddau@linuxcnc
- Thank you received: 29
06 Sep 2022 15:29 - 06 Sep 2022 15:31 #251303
by macsddau@linuxcnc
Join following error in sim mode - SOLVED was created by macsddau@linuxcnc
Hi
Get "Join 1 following error" running 2.9pre (last build on sunday) in SIM mode on Ubuntu 20.04.
$uname -a Linux PCL21-1 5.15.0-46-generic #49~20.04.1-Ubuntu SMP Thu Aug 4 19:15:44 UT C 2022 x86_64 x86_64 x86_64 GNU/LinuxINI & HAL attached
Last edit: 06 Sep 2022 15:31 by macsddau@linuxcnc.
- Thank you received: 7462
06 Sep 2022 16:05 #251313
Replied by tommylight on topic Join following error in sim mode - SOLVED
In your ini file, there are max_velocity for each axis set to 200 and that is OK as that is also the velocity in the TRAJ and Display section, but there are 283 set for each joint, it should be 200.
- macsddau@linuxcnc
06 Sep 2022 16:11 #251316
Replied by macsddau@linuxcnc on topic Join following error in sim mode - SOLVED
I have tried [JOINn]MAX_VELOCITY=200 (commented line) with the same result. This is the reason why I raise this value.
- macsddau@linuxcnc
13 Sep 2022 20:43 #251844
Hi
Apparently, it seems to be linked to this version/install. I have transferred the configuration files onto a 2.8.3 Debian RTPré. All works fine.
From my point of view it is SOLVED !
Time to create page: 0.472 seconds
