- LinuxCNC
- General LinuxCNC Questions
- I'm looking for someone good with Linuxcnc preferably in Oklahoma.
- Mrclark
06 Sep 2022 16:46 #251324
by Mrclark
I'm looking for someone good with Linuxcnc preferably in Oklahoma. was created by Mrclark
I have a CNC router that operates off linuxcnc. I would like to hire someone for tutoring with some of these things. I'm located in north central Oklahoma, would pay some travel cost I just don't want to pay someone from New York City to come to Oklahoma.
Saving all my machine settings to a backup Drive.
Setting up a tool changer.
Possibly installing another axis for turnings.
Tutoring on linuxcnc
Thanks Jeff
jeff at clarkwoodenproducts.com
Thanks Jeff
- Thank you received: 1471
06 Sep 2022 18:48 #251332
Replied by Todd Zuercher on topic I'm looking for someone good with Linuxcnc preferably in Oklahoma.
Backing up and saving your machine configuration settings is super easy in Linuxcnc. Connect the drive media you wish to save the back up to, then using a file manager select and copy the Linuxcnc directory in your home directory and save it to your backup location.
Unfortunately setting up a tool changer is not a simple task. I would consider it an advanced machine integration topic.
Adding an axis, to a configuration is a much simpler task.
Did you set up your machine config that you have now yourself, or did you buy a pre fitted machine?
- Mrclark
06 Sep 2022 18:54 #251334
by Mrclark
Replied by Mrclark on topic I'm looking for someone good with Linuxcnc preferably in Oklahoma.
I purchased it using linuxcnc. It came with the computer. It was a Laguna and the person forgot to tell me that he changed it over to Linuxcnc.
06 Sep 2022 19:01 #251336
Unfortunately I'm in Ohio, so it isn't going to be practical for me to pay you a visit.
Does your router already have an ATC spindle? (ATC=automatic tool change) Or is this an upgrade you are considering?
- Thank you received: 7462
06 Sep 2022 19:06 #251337
Replied by tommylight on topic I'm looking for someone good with Linuxcnc preferably in Oklahoma.
Personally i would consider it a bonus if the machine came with LinuxCNC, saves you the hastle of converting it.
As Todd elegantly put it, some stuff is very easy, as for the more complicated stuff we can help always, and if you have some spare time to read the forum you will quickly see that we help people fix machines all over the world, so distance is not an issue.
What might be the hardest part is having someone with a bit of time and willing to ask and read here, that is all.
The following user(s) said Thank You: Mrclark
- Mrclark
06 Sep 2022 19:07 #251338
by Mrclark
Yes it already has a air operated Chuck.. So right now I'm just going to push the button on the side that releases the chuck and slide another chuck in and release the button.
08 Sep 2022 00:57 #251454
Does the machine have a means of holding the waiting tools? Such as a rack or carousel.
- Mrclark
19 Sep 2022 12:04 #252337
by Mrclark
The CNC router does not have a rack yet but I'm sure I can build it. I do have some of the brackets.
- LinuxCNC
Time to create page: 0.135 seconds
