bad character+ used
- foam man
- Thank you received: 5
07 Sep 2022 03:57 #251387
by foam man
bad character+ used was created by foam man
does linux not recognize the + when used to group variables together
- Thank you received: 2173
07 Sep 2022 06:16 #251392
Replied by cmorley on topic bad character+ used
could you give more detail?
- foam man
07 Sep 2022 13:33 #251401
by foam man
Replied by foam man on topic bad character+ used
hi when I wrote #103 + 0.25 as a command, linux says wrong character + used. yet in their instructions on using variables, thats how they write it
- Thank you received: 2163
07 Sep 2022 14:49 #251408
Replied by Aciera on topic bad character+ used
If I remember correctly you would have to put that expression in brackets:
[#103+0.25]
[#103+0.25]
The following user(s) said Thank You: foam man
- Thank you received: 7462
07 Sep 2022 14:52 #251409
Replied by tommylight on topic bad character+ used
Try
[#103 + 0.25]
[#103 + 0.25]
- foam man
07 Sep 2022 16:27 #251417
by foam man
thanks, looks like that worked
07 Sep 2022 16:30 #251418
Oh, Aciera beat me to it !
