Screen saver function on Buster
4 years 1 month ago #251485 by mariusl
Hi
I am looking for a way to permanently disable the screen saver function on Buster. I am running the latest ISO with 2.8.2.
I tried xset but it seems the settings are only valid for the current session. After reboot the screen saver is on again.
Regards
Marius
www.bluearccnc.com
4 years 1 month ago #251488 by robertspark
I install xfce power manager and set everything from that GUI
m.imgur.com/01xhjK4
4 years 1 month ago #251505 by tatel
Hi
AFAIK, latest 2.8.2 ISO doesn't install any screensaver. Do you mean screen blanking? This is what I do:
1- Create a file /etc/X11/xorg.conf.d/10-noblanking.conf (what matters most is the .conf extension, perhaps initial number also) and put this lines on it:
Section "ServerFlags"
  Option "BlankTime" "0"
  Option "StandbyTime" "0"
  Option "SuspendTime" "0"
  Option "OffTime" "0"
EndSection
Section "Extensions"
  Option "DPMS" "Disable"
EndSection
Save changes and exit from text editor, then :
2- Got to Apps menú -> Configuration -> Session Startup. Look for App auto startup. Uncheck light-locker (screen locker, who compels you to give your password to unlock the blank screen)
Done. Your screen will never get blank again and you'll be never asked for any password to unlock the screen. Perhaps I'm not using the correct menu designations, but my desktop is not in english. Not need to install anything. Actually, on 2.7.15 I uninstall xfce4-power-manager, I just don't want it messing with anything.
HTH
The following user(s) said Thank You: Waldemar, macsddau@linuxcnc
4 years 1 month ago #251513 by mariusl
Thanks that worked well.
Regards
Marius
www.bluearccnc.com
4 years 1 month ago - 4 years 1 month ago #251676 by mariusl
HTH
Do you know that xfce4-power-manager causes issues or are you just precautious?
Regards
Marius
www.bluearccnc.com
Last edit: 4 years 1 month ago by mariusl.
4 years 1 month ago #251697 by elf
Replied by elf on topic Screen saver function on Buster
Are these settings documented somewhere?
Time to create page: 0.066 seconds
