Which breakout board do I need
20 Sep 2022 10:39 #252388 by terry1956
Which breakout board do I need was created by terry1956
Hi. I am looking for a linuxcnc breakout board for my lathe conversion to cnc. I am using a closed loop system with nema 34 motors. If possible I would like to use the usb or Lang cable so I can use a more modern pc. However I have know idea which breakout board to purchase. I am in the U.K. thanks
  • Moderator
  • Moderator
20 Sep 2022 12:34 - 20 Sep 2022 12:37 #252396 by tommylight
Replied by tommylight on topic Which breakout board do I need
Mesa 7i92 and 1 or 2 of cheap BOB, or even better get a Mesa 7i96S that has almost eveything you might need, and if you do need more get a Mesa 7i76E now or get any daughter board for the 7i96S later.
All use LAN/Ethernet, all can be expanded with more inputs/outputs, stepgens, pwmgens, encoders, etc.
Never mind the price, if you can afford it get the 7i96S and ask questions later, even the owner of Mesa helps here all the time so support is by far the best on planet Earth.
Look here:
www.mesanet.com
www.mesaus.com
If in USA, or
www.eusurplus.com
If in Europe.
P.S.
No affiliation with Mesa, i am just one of many very satisfied users of their products
Last edit: 20 Sep 2022 12:37 by tommylight. Reason: more info
20 Sep 2022 16:17 #252410 by terry1956
Replied by terry1956 on topic Which breakout board do I need
Thanks. How easy or not is to wire all this up and get it going.
Time to create page: 0.078 seconds
