Machine stall after tool length probing
4 years 1 month ago #252501 by d2inventory
Hi everyone
Sometimes the machine stalls when probing the tool length. Usually at the start of a program which is good so I can just rerun everything and it will be fine. But I kinda wanna know why this happens so I can trust the machine again :D
This is what I do:
Use MDI (or ngc program) to issue an "T1 M6" command
This calls the tool length measuring macro "messen.ngc"
File Name: messen.ngc
File Size:1.52 KB
I added some debug lines to see where exactly the program stalls.
1, 2, 3 -> stall
So the machine is stuck @ line 34  "G1    Z2.5  F500                (frei fahren)"
What is confusing me is when I check the machine status
File Name: machine_state.txt
File Size:5.27 KB
It tells me the command is: "G38.2 Z-10  F25                 (messen fein)"
But the debug message "4" never shows which is before that command.
Also the status shows "current_line    34" which would be a different command (the one above).
Could it be that the probe is jumpy and that is cancelling line 34?
Is there a way can see if it stalled because of a bouncy probe?
(I'm using debouncing in hal already with a value of 3)
4 years 1 month ago #253188 by andypugh
It's intriguing to read the rest of the output. It looks like execution is actually stalled at
motion_line 30
And the reason that you see the numbers is:
read_line 36
To find where the system _really_ is you could try using an  M67  command and watch the output with a halmeter.
Though that doesn't really explain why the code should stall at the probe move. Is it possible that spindle-at speed is false, or feed-hold or adaptive feed are set to zero?
3 years 8 months ago #265436 by Boaschti
I have the same problem with the same file (except positions).
I could create a minimal example to reproduce this behavior. My code stuck in line 21 exactly when probe is touched.
see here:
File Name: test_tasten.ngc
File Size:482 B
I will check your listed pins. spindle-at-speed is definitly low.
3 years 7 months ago #265725 by Boaschti
These are my signals at all G38.2 moves I do in upper .ngc file.
Any Idea?
3 years 7 months ago #265781 by andypugh
LinuxCNC will wait at any feed move (G1, G2, G3) if spindle.0.at-speed is false (as it is here. Slightly confusingly Halshow has dark red for false and yellow for true)
It is usual for spindle.0.at-speed to be driven true if the spindle speed is zero (and commanded to be zero) so you need to look at the HAL logic driving that pin.
3 years 7 months ago #265787 by Boaschti
I set the spindle-at-speed 5 seconds after spindle relay is set.
And I reset the spindle-at-speed when spindle relay is not set.
LinuxCNC waits these 5s if there is a G0, G1 after M3, that is correct.
Does it make sense, setting spindle-at-speed in probing mode although spindle is not running? During probing the spindle must not run.
Why the first G38.2 in my test file are working? spindle-at-speed is here also false.
Time to create page: 0.099 seconds
