Jogging at a certain angle (lathe mode)?
4 years 2 weeks ago #254016 by MRx
@dgarret thank you for your work, I will test it within the next days!
3 years 4 months ago #272907 by vmihalca
I tried the approach of executing an MDI command then aborting, the problem is that it kills the spindle too. Since I have physical joystick, when I return to the neutral position, I do the following: feed-inhibit = true, switch from MDI to manual, feed-inhibit=false.
This way I am not turning off the spindle with abort.
3 years 1 month ago #280092 by TurboStreetCar
This is super interesting for a retrofit im doing. Is there any instruction on how to install this into my config? It seems some of the Github links are broken.
3 years 1 month ago #280095 by TurboStreetCar
Found the sample config, When i run it i receive this message:
"anglejog: dlopen: /usr/lib/linuxcnc/modules/anglejog.so: cannot open shared object file: No such file or directory"
Dont see the anglejog.so file in the sample directory on github.
3 years 1 month ago #280098 by Cant do this anymore bye all
I just did a build of a recent git pull of linuxcnc 2.9 and once built anglejog is included as is the samples.
3 years 1 month ago #280428 by TurboStreetCar
Can you grab that file and post it here so i can add it to my modules folder? Not sure if itll work, but its in a VM so im not really worried about breaking anything.
If that doesn't work, i guess ill have to reinstall linuxcnc at a newer version.
Time to create page: 0.064 seconds
