Jogging at a certain angle (lathe mode)?
4 years 1 month ago #252912 by cmorley
I would think you would need to rewite simple tp for multiple coordinated axes.
But as you inferred the TP is exactly that.
I don't know why the TP is not used for jogging - that would be an interesting question to get answered. My guess is because it was easier.
4 years 1 month ago #252917 by arvidb
Full trajectory planning and jogging needs different kinds of planning: TP needs to be able to (pre-)blend segments, while simple_tp needs to be able to re-plan in realtime, handling nonzero initial conditions (acc, vel).
4 years 1 month ago #253190 by cmorley
Well I assumed the TP would need additional code to do jogging.
The two jobs are not that far apart. setting an MDI G1 X1 f1 and then aborting is very similar to a keyboard jog.
4 years 4 weeks ago #253234 by RotarySMP
The Fanuc control on the Schaublin 125-CCN has something like that implemented, so you can set an angle and then use the jog wheel to move along the angle.
The following user(s) said Thank You: vmihalca
4 years 4 weeks ago - 4 years 4 weeks ago #253246 by Aciera
I know some people will likely be rolling their eyes but a custom kinematic might be a solution for this.
Last edit: 4 years 4 weeks ago by Aciera. Reason: change wording
4 years 4 weeks ago #253247 by arvidb
If you are okay with stopping completely between each new jog target position, then yes, they are very similar. But think about jogging with an MPG. You really need to be able to "pick up" the current motion and continue to a new target.
